replacing radiator
Results 1 to 5 of 5
Cadillac STS-V Series Forum Discussion, replacing radiator in Cadillac V-Series Forums; Has anyone replaced their radiator, I was wondering if anyone could give me some insight on this. It appears mine ...
    chevySS is offline Cadillac Owners Member
    Automobile(s): 2007 STS V
    May 2012
    34
    12
    replacing radiator
    Has anyone replaced their radiator, I was wondering if anyone could give me some insight on this. It appears mine is leaking between the tank and core, by the looks of things i should be able to come straight up, once the a/c lines are removed. And the fans and i'm sure the front clip and everything between. Any help would be greatly appreciated.
    Zzapp's Avatar
    Zzapp is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V mine and 2010 CTS wife's
    Jan 2012
    So. Cal
    112
    Re: replacing radiator
    The lines on top are for the trans cooler, you gotta disconnect those to get fans out, ever other cooler line is mounted to the fan housing....
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    I have take mine out, it not fun u don't have disconnect the AC line but u do need to disconnect the tran line. It also help if you take clip of front cover so u can loosen some of the bolt cause there are bolt from,condensers to radiator.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    There are many things bolted to the fan shroud. Clamps for wires and tubes mostly. It is a real pain to get to them all but not impossible. Removing the bumper cover is worth it.
    May 2012
    34
    12
    thanks so much for helping me out , so to make sure I have this right once I pull the front clip I just need to give the radiator enough room to come out the top by removing the external trans cooler lines and the fan shroud and assembly, As well as remove mounting bolts and loosening up any other heat exchanger necessary, easier said than done I'm sure.
  8. Remove Advertisements
