Need Help again !!!
Results 1 to 4 of 4
Cadillac STS-V Series Forum Discussion, Need Help again !!! in Cadillac V-Series Forums; So i was replacing my intake back to its original one and when i turn my car on it starts ...
    mikey06d3 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CADILLAC STS-V
    Sep 2011
    ANAHEIM HILLS CA
    24
    256
    Need Help again !!!
    So i was replacing my intake back to its original one and when i turn my car on it starts up fine but when the rpm drop its starts to bog then turn off my motor .
    Can anyone help me tell me what went wrong ?
    the code that popped up was P2228 i was reading its my MAF or air filter but i check them and still car is doing the same thing .... SOMEONE HELP ME PLEASE
    Zzapp's Avatar
    Zzapp is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V mine and 2010 CTS wife's
    Jan 2012
    So. Cal
    112
    Re: Need Help again !!!
    Did you plug in the MAF sensor, or take it off the custom filter pipe and put back on the stock intake... also ck the vacuum hose on the Y-pipe insure its connected...
    Zzapp's Avatar
    Jan 2012
    So. Cal
    112
    Mikey I have to ask why are you removing the after market intake, is it for smog check visual inspection?
    kbf250 is offline Cadillac Owners Member
    Automobile(s): 06 STS-V
    May 2010
    60
    82
    Mikey, check the barometric pressure sensor wiring. P2228 is associated with that circuit.
    Sensors are located on left side of supercharger. if you need help let me know. About
    15 minutes from your location.
    Kirk
  7. Remove Advertisements
