Differential Bushing Replacement
Results 1 to 3 of 3
Cadillac STS-V Series Forum Discussion, Differential Bushing Replacement in Cadillac V-Series Forums; I believe this topic has come up before but I couldn't find it using the search tool. Has anyone replaced ...
    BlownV is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    May 2010
    211
    Has anyone replaced their own diff bushings before and could they give a breakdown of the project? I know the shop manual says to completely remove the diff but I have seen tools online that allow you to just drop it and replace while under the vehicle. I am on my second set now with the car and it is due again...this time no warranty though and it is tough to stomach $700 in labor for a $40 part install. Also, does anyone make poly inserts for these instead of rubber? Thanks in advance.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Re: Differential Bushing Replacement
    Check the first gen CTS-V forum. They have the same diff. There is a poly insert.
    May 2010
    211
    Thanks, yea found a couple of guys that have done it. Looks like a pita but definitely worth it to save $700 and do it yourself so that you can use the aftermarket poly bushing.
