Wiring after market amp
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac STS-V Series Forum Discussion, Wiring after market amp in Cadillac V-Series Forums; Hey guys. I am trying to wire an amp into my o6 sts-v for a little more bass. I am ...
    Darknight is offline Cadillac Owners Member
    Automobile(s): 06 Cadillac STS-V 07 Cadillac CTS
    May 2012
    5
    Hey guys.
    I am trying to wire an amp into my o6 sts-v for a little more bass. I am trying to figure out what wires i need to splice into to get the signal to my amp. i have found the bose amplifier and there are a lot of wires. does anyone have any ideas? or a wiring Diagram?
    KingOfLacs is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V Allante, 2 Eldo's V8 STS CTS-V DTS CTS Fleetwood
    Dec 2011
    34
    320
    Re: Wiring after market amp
    12 volt ignition on under rear seat (remote) inside fuse box
    tap rear door speaker for rca or factory sub
    run power from bettery
    hook sub box to amp
    ground amp then walla bump in trunk
    May 2012
    5
    when i tap the speaker wire, should i just go straight form the wire to rca? or do i need an in line converter
    Dec 2011
    34
    320
    Dec 2011
    34
    320
    Dec 2011
    34
    320
    Quote Originally Posted by Darknight View Post
    Converter
    May 2012
    5
    its super quiet? why is that
    May 2012
    5
    how did you attach your converter? both positives on the converter to the speaker positive and both negatives to the speaker negative?
    Dec 2011
    34
    320
    Sorry been outta town did you figure it out ?
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    It's super quiet because you don't need a converter. The line going to the sub is already low level.
    Dec 2011
    34
    320
    you sure tim where do the rca cables come from without one?
    Feb 2009
    37
    1,897
    I'm sure. I know because I did it on my last STS. I wired in a converter and it was super quiet. Luckily the converter had a switch for speaker level input or low level. I set it to low level and all was corrected. I left the converter in there but I did not need it. I would wire rca cables directly if I were to put something in the V.
    PNBLWZD is offline Cadillac Owners Fanatic
    Jun 2010
    Los Angeles, CA
    46
    303
    So if I were to use an amp that wants to see both L and R low level inputs, which ones would I use? Rear doors or front doors? If so, when tapping the wires coming from the Bose module in the trunk, does anyone have the wire color codes?
  16. #14
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    on the Subwoofer:
    A) Power
    B) Ground
    C) Control
    D) Woofer (-) from Amp.
    E) Woofer (+) from Amp.
  17. #15
    Feb 2009
    37
    1,897
    Just split the signal. Don't feed the sub amp door speaker signals unless you want to use different crossover settings than stock.
  18. Remove Advertisements
