JMS PowerMax FuelMax fuel pump voltage booster
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, JMS PowerMax FuelMax fuel pump voltage booster in Cadillac V-Series Forums; While doing research on Kenne Bell BAP I found another product that claims to be better than the Kenne Bell ...
    Zzapp's Avatar
    Zzapp is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V mine and 2010 CTS wife's
    Jan 2012
    So. Cal
    112
    While doing research on Kenne Bell BAP I found another product that claims to be better than the Kenne Bell system. Has anyone used the JMS fuel pump voltage booster? The information I've seen so far looks good however it is mostly sponsered by JMS or their sister company....
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    Re: JMS PowerMax FuelMax fuel pump voltage booster
    The Kenne Bell is cheaper and I would feel better having that then someone I have never heard of. Not syaing there is anything wrong with it, just feel better with a known brand.
    FKALS1 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jun 2012
    42
    1
    I know this is my first post but i did not find an introduction thread. The JMS powermax unit is a good unit as I have used one on a past project i recently sold. Those guys have always tuned cars for me in the past and know the business very good. The company SCT started from that very shop. The owner of SCT owns JMS as well. Anyways im not here to give history on someone just opinion about the product. I ordered one for my cobra, and vette as they have a gm specific model too. Good unit and worth the extra ! Can someone direct me to where i can do a formal introduction so i do not get banned etc. Thanks in advanced.
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    Welcome aboard FKALS1
    First I recommend you fill out the My Profile area, especially if you have a Cadillac in your stable. If you are a V owner, drop a reply in the 'Tell us about your STS-V' Sticky thread at the top of the STS-V page
    Have you reviewed the full forum list yet? http://www.cadillacforums.com/forums/forum.php In the 'Community Lounge' area you'll find a wide variety of Cadillac fans (and a few not-so-fans) and can introduce yourself there as well.
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    slightly off topic? is the pump in these cars speed controlled by the computer?
    Zzapp's Avatar
    Jan 2012
    So. Cal
    112
    yes it is
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    No, it is not.
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    You can change the pump type, time to prime the pump, and the duty cycle percentages and that's it.
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    This unit is the best one i have seen so far.
    You can test all the units available with simple electronic tools and see the exact same results.
    This one puts out the highest amps of all on the market.
    It has the Cleanest signals of all on the market.
    It has a ramp in rate which helps alot on keeping the fpdm happy and reduces pressure spikes and FPDM cell learns and electronic feedback thru the data bus that messes with abs and other quirks usally seen with others in our cars.
    The only thing that would make it better is if it had even more amp reserve for the 1000hp kind of stuff, but for regular 800hp down it works just fine.
    I use these boosters in almost every car we do now with very good results.
    As for the computer being in control of the fuel pumps, TECHNICALLY it is in control, because it tells the fuel pump computer what it needs to for fuel pressure.
    Everything is target vs actual. So the ENGINE computer TELLS the fuel pump computer that it wants to be 60psi "as an example" then the fuel pump computer will modify the pulse width modulation to the pump itself to achieve that pressure.
    It will learn / add/subtract the pwm of the pump to hit the goals, and only follows what the ENGINE computer is asking for.
    Zzapp's Avatar
    Jan 2012
    So. Cal
    112
    According to the Cadi STS-V repair manual the fuel pump is controlled by the Electric Control Module(ECM)
    Feb 2009
    37
    1,897
    The computer only turns the pump on in the STS-V. There is no fuel pressure sensor and no fuel pump computer. There is a pressure regulator built into the fuel filter and that's it. Look at the screen cap of the calibration.
    wait4me's Avatar
    Jan 2009
    warsaw indiana
    2,997
    He is correct, sorry i thought this was the 2009 up cts V section. Guess i should have looked. The CTS v has a fpdm. The STS v is just on/ off.
  15. Remove Advertisements
