Which fuel upgrade injectors, fuel pump, or both?
Results 1 to 10 of 10
Cadillac STS-V Series Forum Discussion, Which fuel upgrade injectors, fuel pump, or both? in Cadillac V-Series Forums; I've upgraded my exhaust with a home fabricated Dynamax cat back system, D3 stage 1 & 2 intake, frozone/flexlite intercoolers, ...
    Zzapp's Avatar
    Zzapp is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V mine and 2010 CTS wife's
    Jan 2012
    So. Cal
    112
    I've upgraded my exhaust with a home fabricated Dynamax cat back system, D3 stage 1 & 2 intake, frozone/flexlite intercoolers, 160 thermostat, my car is currently apart as I have sent my blower pulley snout to TimmyC, and I have a D3 lower OD crank pulley I'm putting on while waiting for my TimmyC upgrade... Should I upgrade the injectors, fuel pump, or both before I get a Dyno tune... What injectors should I use, and which fuel pump???
    Psycho-albanian is offline Cadillac Owners Fanatic
    Automobile(s): STS_V
    May 2010
    277
    Re: Which fuel upgrade injectors, fuel pump, or both?
    TimmyC or coach would be the guys to ask.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    I don't know what pump you could get other than a boost a pump. With that you could wait to change injectors (I think). Talk to Tim about the BAP. I changed my injectors to a set of Seimens 73lb Ford Racing and scaled my tune for them. The problem is that our tune limits the Injector Flow to a point we have to scale it to use anything above 63.5lb. Before my injectors I was running 98% duty cycle, now with them I am only running 55% so I have plenty of headroom for my pulley.
    The other guys that upgraded their injectors just had their stock injectors redrilled.
    I will be very interested in your results with the lower and upper combination and your numbers.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Stock injectors with a BAP and a boost referenced fuel system are good for around 550rwhp. I made 575 with this setup but it was leaning out at the end of a dyno pull. Stock injectors with just the BAP are good for 430. My car makes more than that but it starts to lean out at 6000rpm.
    The stock fuel system is 58psi no matter what the pressure in the manifold is. In vacuum there is a greater pressure difference across the injector than in boost. A boost referenced fuel system uses a pressure regulator that references the pressure in the intake manifold and keeps the fuel pressure 58psi above that. That way fuel pressure increases with boost and the injectors can flow more. Conversely, the fuel pump's output drops as fuel pressure increases so you need the BAP.
    I think the stock fuel pump will go at least 460rwhp with bigger injectors. Bigger injectors flow more fuel at stock pressure to a point.
    BAPs are around $270 I think and I could make boost reference kits for $250 so this route might cost more than bigger injectors. However, even with bigger injectors the fuel pump is going to be the limiting factor. I prefer a BAP to an aftermarket fuel pump for two reasons. One is that aftermarket pumps are not as reliable as oem pumps. Two is that the fuel tank in an STS is a pain in the ass to remove. You have to partially drop the rear suspension cradle.
    These are the reasons I kept the stock injectors with a BAP and referenced fuel system.
    Zzapp's Avatar
    Jan 2012
    So. Cal
    112
    BAP? what's that?
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Boost A Pump- It increases the voltage to the fuel pump.
    Zzapp's Avatar
    Jan 2012
    So. Cal
    112
    With the increased voltage to the stock fuel pump have there been any longevity issues?
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    There have been no issues on other applications but only Tim has tested it on ours.
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    What do u mean by the fuel reference system?
    Feb 2009
    37
    1,897
    Quote Originally Posted by Carlosg View Post
    Read paragraph two of post four in this thread.
  13. Remove Advertisements
