Aftermarket sub/amp install.
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Like Tree4Likes
Cadillac STS-V Series Forum Discussion, Aftermarket sub/amp install. in Cadillac V-Series Forums; I am trying to figure out how to wire in my aftermarket amp with my stock setup. I don't want ...
    AriGold. is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Jan 2011
    Tulsa, Oklahoma
    143
    I am trying to figure out how to wire in my aftermarket amp with my stock setup. I don't want to buy a converter. There was a thread years back but I cant find anything current. Anyone know? Wanting to keep everything stock. adding a 500 watt amp and 1 p3
    KingOfLacs is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V Allante, 2 Eldo's V8 STS CTS-V DTS CTS Fleetwood
    Dec 2011
    34
    320
    Re: Aftermarket sub/amp install.
    12 ignition under rear seat (remote)
    tap rear door speaker for rca
    run power from bettery
    ground then walla bump in trunk
    leija_01, leija_01 and baller95 like this.
    Jan 2011
    Tulsa, Oklahoma
    143
    Quote Originally Posted by KingOfLacs
    Tap rear door speakers? What do you mean? Do I need to buy anything other then the amp kit.
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Sep 2010
    277
    Quote Originally Posted by AriGold. View Post
    Just stop this idea right now if you don't understand what he just said. You're only going to create a mess for yourself. Turn the bass up if you want more bump.
    baller95 likes this.
    Jan 2011
    Tulsa, Oklahoma
    143
    Quote Originally Posted by YoungBlood_STSV
    I didn't want to have to install a converter.
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    u have no choice unless you get a new headunit with a sub out. the factory units typically can only support front/rear speaker operation and you cant add a sub/amp without stealing from one of those for single. your choices are simple, get a new headunit and redo everything. tap the rear speakers and be done. or, pay a shop an ungodly amount to do what i just said.
    Jan 2011
    Tulsa, Oklahoma
    143
    Tapped the speakers, Thanks everyone.
    KingOfLacs and KingOfLacs like this.
    Dec 2011
    34
    320
    yeah converters are cheap and you get to keep your factory setup. Put some pics up of your setup
    Dec 2011
    34
    320
    PNBLWZD is offline Cadillac Owners Fanatic
    Jun 2010
    Los Angeles, CA
    46
    303
    Couldn't you use the signal going to the factory 12" sub to feed the low level input of the new amp?
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Quote Originally Posted by PNBLWZD View Post
    Yes. The sub has the amp integrated into it so the signal is already low level. No need for a converter.
    Dec 2011
    34
    320
    just the way I always done it never said it was perfect just working ....
    youknooow is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V 1 OF 3 BLK ICE & TANGO RED
    Dec 2010
    630
    Can we add tweeters to our setup?
  16. #14
    Jun 2010
    Los Angeles, CA
    46
    303
    Kingoflacs, with your subs/box facing rearward, does it cause a lot of rattles on the trunk lid and license plate? Did you remove the factory 12" to allow more sound to come into the interior?
  17. #15
    Dec 2011
    Missouri
    31
    894
    u can add whatever youd like to it. just be willing to do the work. the factory bose systems are 8ohm making them incompatiable with other options on the market. if you want to start getting into new speakers, your better off running a new system. front to back, replace it all. that said, all things are possible and adding a few tweeters for better treble can be accomplished its just a pain and the end result probably wont satisify you much.
  18. Remove Advertisements
