These Key Fobs kinda blow
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Cadillac STS-V Series Forum Discussion, These Key Fobs kinda blow in Cadillac V-Series Forums; Have an 07, and it's not remote starting anymore, do I need to change the battery. Can I do it ...
    choigilligan is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Aug 2010
    195
    Have an 07, and it's not remote starting anymore, do I need to change the battery. Can I do it myself...
    Just feeling lazy and don't feel like looking, any advice would be good.
    BTW does anyone else think the fob on this car is weak, people can unlock their cars from a long ways
    away, I have to be pretty close, less than 75 feet...
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    The key fob battery is easy to change. Use a coin to wedge open the fob in the notch around the edge.
    It's usually a CR2032 battery, about $3-$7 bucks.
    Then there's the chin trick for distance. Press the fob against your chin as you press the button, the effective range is said to increase significantly.
    Go ahead, try it at night in the dark so no one sees you doing it. I think it works.
    parkeraire's Avatar
    parkeraire is offline Cadillac Owners Fanatic
    Automobile(s): 06' sts-v
    Mar 2011
    Lee Co. FL.
    47
    169
    Re: These Key Fobs kinda blow
    Probably battery cause mine will work from 100+ yards.
    550HP STSV Guest
    upgrade to an 08+ fob for double range.
    fast_lane10 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS - V
    Mar 2010
    Chicago
    39
    255
    I have an 07 too.. I talked to dealer about it and they said as per GM the range is 50 ft, which i think is kinds lame because i cant start it from my office building as i park at the end of parking lot. There is another post where someone mentioned that remote start worked for them in a building where the car is not in sight and they advised to change the battery .. which I did and first couple of time after that the remote start worked like a charm from far away too.. but then back to same range. I bought 5 batteries from amazon for 3 bucks.. and i think it was free shipping too. I wanted to try the new fob but am not sure how the kep will work with it .. i am sure if we buy it frm dealer they can make the keys but dont want to spend that kind of money just for fobs..
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    there are actually a few other alternatives to strictly dealer for purchasing key fobs. i havent personally had any expirence with this one, but i do know that the local locksmith for my area can make the computer programmed keys for benz, bmw, licoln and maserati. i cant think why caddy would be off the list. you may want to call around and see if any of the smiths in your area can do it. i know a 400 fob for my bros lincoln cost 230 programmed this way. just my two cents.
    Aug 2010
    195
    Quote Originally Posted by 550HP STSV View Post
    I asked a couple of places if the 08 key would work for an 07 and they said it would not... are they wrong?
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Quote Originally Posted by choigilligan View Post
    They are wrong. See thread in sts forum.
    The Raven's Avatar
    The Raven is offline Cadillac Owners Enthusiast
    Apr 2010
    Fleetwood, PA
    36
    825
    If you are having range problems, replace the battery. My fob's batteries are over a year old now and I can still start the car from damn near 500ft away.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    also remember if your check engine light is on then remote starting is disabled
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    or a history code too!
    KingOfLacs is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V Allante, 2 Eldo's V8 STS CTS-V DTS CTS Fleetwood
    Dec 2011
    34
    320
    Anyone with the 06-07 STS-V done a 08 Fob yet how hard was it did you need a tech 2 to program?
    550HP STSV Guest
    I did, and yes.
  16. #14
    Dec 2011
    34
    320
    Thats the fancy squarish one with the crest correct also part number would be great if you have it. Lastly need the 5 button one I want remote start to work
    http://www.ebay.com/itm/CADILLAC-SRX...#ht_574wt_1189
  17. #15
    The Raven's Avatar
    Apr 2010
    Fleetwood, PA
    36
    825
    Quote Originally Posted by KingOfLacs View Post
    The trick to it is you MUST get an STS fob...even though the DTS fobs look the same, they are not the same. Only STS fobs will work. If I remember correctly, you can verify that it is an STS fob by looking for the key release button...the DTS fobs don't have this.
  18. Remove Advertisements
