Will a Front Wheel Mount on the Rear?
Results 1 to 3 of 3
Cadillac STS-V Series Forum Discussion, Will a Front Wheel Mount on the Rear? in Cadillac V-Series Forums; Will a front wheel fit on the rear and clear the caliper. I have a front Hankook Ventus V12 with ...
    CQQL_STS-V is offline Cadillac Owners Member
    Automobile(s): 2014 CTS-V Wagon ROT/Black, Auto, Polished Wheels
    Jan 2010
    Pembroke, MA
    70
    62
    I have a front Hankook Ventus V12 with a bubble on the sidewall.
    I purchased a replacement tire because they said I hit a pot hole and damaged the tire.
    The tire only has about 5k miles on it and I can't see throwing it away.
    I was thinking about buying a front rim (or a whole set of chrome ones) and using the wheel as a spare.
    I figure I have a 50/50 chance of blowing out a front tire but you know how Murphy's Law works.
    Charlie
    Xtreme70SS is offline Cadillac Owners Fanatic
    Automobile(s): SRX, STS-V
    Apr 2011
    131
    Re: Will a Front Wheel Mount on the Rear?
    You won't want to run 2 different size tire combinations on either side of a limited slip differential. Keep it for the front if you must, but I wouldn't use it on the rear.
    Better bet would be to get the temporary plug kits (they run under $10), and an air compressor to fix a flat. Won't help with a blowout though. I've used the plugs with great results before - just make sure you have it properly fixed when you can.
    Jan 2010
    Pembroke, MA
    70
    62
    Quote Originally Posted by Xtreme70SS View Post
    Great idea!!
    Leaving on Thursday for Watkins Glen, NY. I don't want to get stuck on the way out, the way back or on the race track on Saturday.
    I will pick up a compressor and plug kit tomorrow.
    Thank you,
    Charlie
