Last Resort For Help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Cadillac STS-V Series Forum Discussion, Last Resort For Help in Cadillac V-Series Forums; I had the same problem with my old 2006 STS-V. Went to the dealer three separate times. 1st they replaced ...
  1. #16
    flyingv's Avatar
    flyingv is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V 6MT
    Jan 2006
    Burbank, CA
    35
    109
    Re: Last Resort For Help
    I had the same problem with my old 2006 STS-V. Went to the dealer three separate times. 1st they replaced the coolant senor, then they replaced the thermostat, finally they reprogrammed the ecm (there was an update around that time) and the problem went away. A thermostat is a very simple mechanical device so I find it hard to believe you could have a defective one. If you still have the problem after the new t-stat let me know and I'll dig up all the paperwork from the dealer to help you out. Good luck.
  2. #17
    AnthonyS is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    Jan 2010
    Central Coast, Ca
    32
    57
    Thank you very much. It's at the dealer now, been there since 8:30 this morning (4:40pm now) Hopefully it's something easily fixed. Once I get it back today I'll post what the verdict was.
  3. #18
    550HP STSV Guest
    let us know!
  5. #19
    Jan 2010
    Central Coast, Ca
    32
    57
    Just got a call from the dealer. It WAS pulling, P0126 -Insufficient Coolant Temperature for Stable Operation
    They also seen and are currently fixing the shifter because I started getting a "Shift into Park" message. Glad that I will be getting a perfectly working car finally. Thats again for all your help.
  6. #20
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    So are they putting in a 180* then?
    The Shift to park is the Neutral Saftey Switch or as GM calls it "Transmission Position Sensor". Glad they are fixing that too? Is this warranty work or are you bellying up to the plate?
  7. #21
    Jan 2010
    Central Coast, Ca
    32
    57
    Yeah they're putting a 180 back in. The paperwork shows they tried to adjust the shift linkage with no luck fixing it. They suggested replacing the shift control assembly. Do you think the sensor needs to be replaced instead of the whole assembly?
  8. #22
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    It is probably going to be the netural saftey switch that I refered to. If you search for all post by me you can find other threads that talk about this.
  9. #23
    Jan 2010
    Central Coast, Ca
    32
    57
    I'll do that, thank you. Looked at your Dreaded "Shift into Park" thread. I'll stop by the dealer tomorrow and tell them about this, hopefully they will cover it since it's an internal part.
  10. #24
    Jan 2010
    Central Coast, Ca
    32
    57
    Just left the dealer service, they said they need to replace the whole thing. Does the sensor have a part # that I can have another mechanic replace?
  11. Remove Advertisements
