Results 1 to 5 of 5
Thread: A/C recharge port
    rakoom2002 is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Nov 2010
    32
    178
    A/C recharge port
    Hey guys, could someone tell me where the low pressure a/c recharge port is? I dont wanna screw it up and put it in the wrong port. Ive read that they make em now so they wont fit on the high port, and I also read that the pipe for the low pressure port will always be bigger then the pipe for the high pressure port. Anyways, thanks for the help.
    Nov 2010
    32
    178
    Re: A/C recharge port
    would it be #4 in this diagram?
    STS-V A/C Line Diagram
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    That's it. Start car, put AC on max cold, hook up recharge hose, pull trigger. Check pressure till it gets in the 40-45psi range when the compressor is running. Very easy.
    Did you find the front end parts you needed?
  5. #4
    Nov 2010
    32
    178
    Quote Originally Posted by TimmyC View Post
    Thanks for the information man. As far as the front end parts, do you mean the radiator and a/c condenser?
  6. #5
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    Chicago
    44
    1,328
    FYI, on all newer cars, the low pressure fitting and high pressure fitting are two different sizes specifically to save against someone putting them on the wrong fitting. As such, the hose you have that you connect to the can of R-134a (or machine), should only fit on the low pressure side fitting. The high pressure side is a bigger fitting, so the coupler on your hose won't fit over it.
  • You may not post replies
