Engine HOT - A/C off on 2006 STS-V - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 74 of 74
Like Tree2Likes
Cadillac STS-V Series Forum Discussion, Engine HOT - A/C off on 2006 STS-V in Cadillac V-Series Forums; DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature The engine coolant temperature (ECT) sensor is a variable resistor that ...
  1. #61
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    Re: Engine HOT - A/C off on 2006 STS-V
    DTC P0128
    The engine coolant temperature (ECT) sensor is a variable resistor that measures the temperature of the engine coolant. The engine control module (ECM) supplies 5 volts to the ECT sensor signal circuit and supplies a ground to the low reference circuit.
    The purpose of this diagnostic is to analyze the performance of the thermostat, by using the ECT sensor to determine if the engine coolant will increase at the correct rate, and also meet the calibrated target temperatures under various operating conditions.
    The ECM uses the start-up ECT and the start-up intake air temperature (IAT) to begin the diagnostic calculation. The air flow into the engine is accumulated , and vehicle speed, distance, and engine run time are also factored in to determine if the ECT does increase normally and reach the calibrated target temperatures.
    straight from service info for gm if that helps you out any
  2. #62
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Ok cool thanks for that. My last question then is how do you "set the code to no report?" Is this a function on the obd II scanner?
  3. #63
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    You need HPtuners for that.
    Guy.Seminerio likes this.
  4. #64
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks a lot
  5. #65
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Quote Originally Posted by TimmyC View Post
    Or EFI Live.
  6. #66
    Feb 2013
    Whitestone, NY
    28
    3,211
    Gotcha
  7. #67
    Ninja-v is offline Cadillac Owners Fanatic
    Automobile(s): 2007 sts-v, 2011 Escalade EXT
    May 2013
    28
    375
    I just bought a 160 degree stat for an ls1 by mr gasket. I have hp tune pro. What do I need to adjust to reap the benefits?
  8. #68
    Feb 2009
    37
    1,892
    Just turn off that p0128 code.
  9. #69
    May 2013
    28
    375
    Where do you find that at?
  10. #70
    Feb 2009
    37
    1,892
    engine diag dtcs
  11. #71
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    You might also want to modify your fan speed tables.
  12. #72
    May 2013
    28
    375
    That's what I was thinking too. And the part of the tune that deals with those temps
  13. #73
    Feb 2009
    37
    1,892
    The lowest temp that the fans will turn on is 192F so your engine is not going to run cooler than that in the summer. I have the stock 176F thermostat in my car and it runs at 195-205 in the summer. That is already 20 degrees hotter than the thermostat opens. The thermostat sets the lowest temp that the car will run. The fans set the highest. You need an aftermarket method to turn the fans on for it to maintain less than 192 degrees.
    YoungBlood_STSV likes this.
  14. #74
    chekasout is offline Cadillac Owners Member
    Oct 2010
    13
    once again, this forum saves the day!!!i was flippin with the ac off mssg. i was running 174 oil temp, and had the heat on full blast to dissipate the heat because i thought that was a high temp. i thought thermostat, first thing. thanks for the mind-calming post!!!!!
  15. Remove Advertisements
