Engine HOT - A/C off on 2006 STS-V - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 74
Like Tree2Likes
Cadillac STS-V Series Forum Discussion, Engine HOT - A/C off on 2006 STS-V in Cadillac V-Series Forums; Ugh, this stupid light keeps coming on. Replacing Thermo, and Water Pump since it's leaking. The damn dealer wanted around ...
  1. #31
    rakoom2002 is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Nov 2010
    31
    178
    Re: Engine HOT - A/C off on 2006 STS-V
    Ugh, this stupid light keeps coming on. Replacing Thermo, and Water Pump since it's leaking. The damn dealer wanted around $1000 to fix both lol. Luckily one of their retired mechanics just lives up the street from me.
  2. #32
    KingOfLacs is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V Allante, 2 Eldo's V8 STS CTS-V DTS CTS Fleetwood
    Dec 2011
    34
    319
    temp gauge is not working as of last night. After reading this post it looks like I have the same issue with bad t=stat (engine hot a/c off). Dublin Caddy ordered parts will have to wait till Friday their coming from reno. I was going to put the stock factory t-stat back in whadda think. Also going for a tune and exhaust any input would be helpful.
    Joe
  3. #33
    Dec 2011
    34
    319
    Ok factory delco t-stat in no more hot engine shoot on my dash hell yes
  5. #34
    Chuck. is offline Cadillac Owners Member
    Automobile(s): 08 STS-V
    Oct 2011
    32
    20
    I had the same problem replaced t-stat and it has not come back its been a month.
  6. #35
    Bradkoen is offline Cadillac Owners Member
    Automobile(s): NONE
    Jan 2011
    Austin, Tx
    46
    15
    I have the same problem even after changing the Tsat. The water pump was replaced 2 months ago under warranty. Any other suggestions? I might go try unplugging the positive battery cable for 30 seconds, but I am not optimistic about this working.
  7. #36
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    You might pull out the T-Stat and test it. There have been some bad right out of the box.
  8. #37
    Automobile(s): NONE
    Jan 2011
    Austin, Tx
    46
    15
    Replaced the new Tstat with yet another Tstat and got the same results. Not to sure how to test them, cause I dropped them in hot boiling water and could see anything change. So, I decided I would try the removal of the positive battery terminal for 30 seconds and whahla, the temp. gauge started to working and the error message went away. Darn, what a way to spend my day off.
  9. #38
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    When you put it on boiling water it should open. It should open somewhere near the rated temp.
  10. #39
    550HP STSV Guest
    Jamie, pay your damn cell phone bill. I just called it and it said its disconnected. call me
  11. #40
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Quote Originally Posted by 550HP STSV View Post
    Jamie, pay your damn cell phone bill. I just called it and it said its disconnected. call me 866-236-5031
    It would help if you called the right number..........
  12. #41
    550HP STSV Guest
    is 816-885-xxxx not your old number?
  13. #42
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Optimum word being "OLD"
    Now get back to the topic!
  14. #43
    Dec 2011
    34
    319
    Did It again just replaced t-stat think it could be the actual temp sensor? Temp gauge not working light comes on engine hot / ac off oil temp is between 158-165.
  15. #44
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Are you throwing any codes? Could be the temp sensor but I don't know of any easy way to test it.
  16. #45
    Dec 2011
    34
    319
    Yup finally threw a code had to drive it for a while. Scanned it P0128 coolant temp below Thremostat regulating temp. Cleared it we shall see if it comes back on. I haven't driven it since then i will chime in if it does.
  17. Remove Advertisements
