Thermostat Replacement with OEM?
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, Thermostat Replacement with OEM? in Cadillac V-Series Forums; Those of you who had their thermostat replaced with a new OEM part, have you has the "ENGINE HOT - ...
    jerrylsantos is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V
    Jan 2011
    Sacramento, CA
    33
    84
    Those of you who had their thermostat replaced with a new OEM part, have you has the "ENGINE HOT - AC OFF" error ever return? If the actual design is faulty, should I just have a third party (Stant or similar) installed?
    I'm at about 47k and have been getting the notorious message, and i'm finally getting around to getting the thermostat replaced. Warranty is out, so I was going to find a shop to do it, and flush my coolant at the same time.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    Re: Thermostat Replacement with OEM?
    Without a warranty you will save a bunch of money going to a local shop other than a dealer. Nothing special about the T-Stat. The Stock is a 180* and part number Mr. Gasket 6368.
    I replaced mine with a Mr. Gasket 6367 160* T-Stat. Please note I also have HP Tuner so I can tune for it.
    550HP STSV Guest
    What exactly are you tuning? Could users with the Spectre intake use a 160 safely, without a tune?
    Jan 2011
    Sacramento, CA
    33
    84
    Basically, i was wondering if a replacement OEM thermostat would fail again.
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Quote Originally Posted by 550HP STSV View Post
    Turning off P0128 (Coolant Low Temp Failure) so it won't set a CEL. You might get away with not turning off the code but you run the risk of getting it. But only with the 160*
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Quote Originally Posted by jerrylsantos View Post
    If it truly is the T-Stat then no it should not fail again.
    Jan 2011
    Sacramento, CA
    33
    84
    So what was it about the Thermostat that came from the factory that made it faulty? Does it just reach end of life?
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    I took out my Factory and it was still fine. I just wanted the 160*.
    Jan 2011
    Sacramento, CA
    33
    84
    ...I realize that, that is why I am trying to steer the thread back in topic.
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Sorry I was just trying to answer your question about having someone change it for you and what to use. You can do it yourself if you have a deep 10mm socket. Its just 2 bolts and you don't even have to take off any hoses.
    I think the factory has a tendency to freeze up and not open correctly.
    Jan 2011
    Sacramento, CA
    33
    84
    Thanks for the info. Searches turned up people getting it replaced under warranty, or people who installed a lower temp thermostat. I'm still unsure if I should get an oem part, or a Stanton (or other) "factory" replacement.
    While you brought it up; I was under the impression that at least some of the coolant had to be drained to get to the thermostat? If that's not the case I'll swap the part out now and do a flush a little later.
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Nope. You loose a small amount when you take it off so obviously do it when the car is cold. I would bet it is 2 cups or less. It was not even enough to trigger a low coolant warning. The system will purge by itself. I just opened the overflow tank a few times to let out the air after she ran for a while. Any local parts store should have a factory style replacement for under $25. I reused the factory rubber gasket as it has an additional ring around another tube. You will see what I mean when you get to looking at it. The hardest part was getting the factory T-Stat out of the housing. Mine was wedged in there pretty good.
  15. Remove Advertisements
