gtech chip?
Results 1 to 9 of 9
Cadillac STS-V Series Forum Discussion, gtech chip? in Cadillac V-Series Forums; Has anyone tried the gforce chip? Is it worth it or a waste of money? My car is stock except ...
    alphadad is offline Cadillac Owners Member
    Automobile(s): 2006 sts-v
    Mar 2011
    47
    3
    gtech chip?
    Has anyone tried the gforce chip? Is it worth it or a waste of money? My car is stock except tires. I have hankooks.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,600
    Re: gtech chip?
    Never heard of it. ?
    Mar 2011
    47
    3
    Re: gtech chip?
    My bad. It is called Gforce.
    Mar 2011
    47
    3
    Re: gtech chip?
    The only reason I ask is because my buddy has one on his Qvale and says he likes the gains it provided. Improved mileage and throttle response, as well as it feels like it has more power although not dyno proven.
    550HP STSV Guest
    Re: gtech chip?
    this cannot be a real question.
    nlharter is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    Jun 2009
    SW Missouri
    39
    76
    Re: gtech chip?
    I think the Gforce chip adds up to three extra hamsterpwer. But they are secret agent hamsters. Sorry, could not let it slide.
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    609
    Re: gtech chip?
    my experience with "chips" in generaly is, better throttle response, lower operting temperature ( Fans are turned on earler), harder shifts, very little hp gains--the ads always say 40hp or thereabouts--last car i had (99TA WS6) got 10 hp on a dyno--- my advice, dont do it for the HP gains alone!!
    Florian's Avatar
    Florian is offline crushing Vs with my Wurm
    Automobile(s): 2013 GT500 - 700+ HP
    Aug 2003
    location, location
    12,266
    Re: gtech chip?
    go have your car tuned on a dyno...less money, better results.
    F
    550HP STSV Guest
    Re: gtech chip?
    Lol, you got 10hp on your trans am by plugging a two wire resistor in?
    Lets ignore the homebrew qualities (hot glue gun, what looks like speaker wire, lack of IC socket, lack of wire strain relief, moderately-bad soldering job) for a moment. Note there are only 2 wires total, the ones that connect to a sensor on your car. Now lets look at the pins the connect to on the IC. (Note: IC = Integrated Circuit, aka chip) Notice only the 2 on the end are connected.
    Now lets take a look at how the most basic IC works. At minimum, 4 things are required:
    1. Positive power (Vcc)
    2. Negative power or ground
    3. Input
    4. Output
    Have you noticed that there's only 2 pins total connected on the chip? Ah-ha! Busted. That's right - the chip in this module is not even powered up! Almost all DIP IC's use pins on opposite diagonal corners for Vcc and Gnd. In this case, it is a 20 pin DIP IC, so pins 10 and 20 should be Gnd and Vcc, respectively. (and most IC's that don't follow this scheme would use pins opposite each other in the center) See this for reference:
    IC power supply pin - Wikipedia, the free encyclopedia
    Additionally, IC's don't like having 'noisy' power that would be typically found in a car. Anything legit would have a basic power supply or regulator to supply the IC with clean, stable power.
    So what is actually happening in this example? The scam artist probably grabbed some random surplus chips (such as some common TTL 7400 series, which go for under $1) and probed various pins with a multi-tester in resistance mode. An unpowered IC will show resistance between certain pins. This is likely the case here, although there's no proof that the maker even bothered to check that the resistance is desirable for use as "traditional" IAT bypass.
    I have an electronics background (Electronics Technology degree) and can safely say that whoever makes this chip does not.
  12. Remove Advertisements
