Upgraded injectors?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Cadillac STS-V Series Forum Discussion, Upgraded injectors? in Cadillac V-Series Forums; What is the model# of the upgraded injectors you snakebite guys are using out there?...
    550HP STSV Guest
    Upgraded injectors?
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Re: Upgraded injectors?
    I'm using Stock resized to 60lbs. But with out my meth on I'm only at 74% duty cycle and with meth 65%. So save you $$$ unless you going to run 17 + psi. IMO Ryan
    550HP STSV Guest
    Ok. I've did some calculating and research.
    Originally, tim had said our injectors are EV-14s - http://fuelinjectorconnection.com/sh...&productId=171
    But Ryan said he had the injecetors resized to 60lbs, as did coach to handle the additional power. So Im thinking our OEM injectors are less, probably 50lb injectors or less?
    Using this form: http://www.rceng.com/technical.aspx
    Shows that if you want to be at 600 BHP (flywheel,) which would be around 470 rwhp (assuming a 22% drivetrain loss) you would need 58lb injectors. Hold on, ill get the part# of our injectors from the crash guide.... not in crash guide. Called my dealer $38 each, 12598842:
    AC DELCO # 217-3076
    GMC # 12598842
    BOSCH # 0-280-158-085
    FLOWS @ 40 lbs 12.20 ohms
    Wow! 40 lbs! Thats nothing! Lets do a little more math....
    Lets say crankshaft horsepower is 469 (manufactor rated.) Assume 22% drivetrain loss... that would be 366 rwhp.
    For 8 injectors, Brake specific consumption should be .55 TO .60 for supercharged engines (we'll assume .55 at normal boost)
    Maximum injector duty cycle of 80%, and System fuel pressure at fuel rail of 43.5 PSI = 40 lbs an hour.
    We are seriously restricted by our injectors.
    So Ryan, where did you get your injectors resized for $175? Or what can we use for a replacement?
    Thanks!
    GoofyGuy is offline Awaiting Email Confirmation
    Automobile(s): 2006 STS-V
    Oct 2010
    Tampa, FL
    34
    209
    boo to resizing!
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,661
    I believe he had Steigmeier do it when he had the Snakebite done. They also flow matched them.
    PGA2B's Avatar
    Jun 2009
    USA
    2,661
    Of course you could get Injector Dynamics ID850!!
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    Same place as the snake bite. But note 4.6 sc cobras make 500rw with 38 or 39 can't remember. And my 6.0l turboed z28 made 498rw and 520tq @10 psi on 42s. So I still say unless you are going to run big boost stock workes fine. I would not have need them with my meth. And you can run them to at least 95% duty cycle I did when my camaro had the 5.7l still in it. Ryan
    550HP STSV Guest
    I dunno... with the temperature's we're seeing with snake bite and upgraded pulleys, do you really want your injectors running at 95% duty cycle? 80% is the max recommended.... Im more concerned as to if this is why people are seeing drop offs above 420 rwhp on their cars, such as where Tim saw a drop off in boost PSI and HP/TQ on his dyno with the new pulley.
    The Raven's Avatar
    The Raven is offline Cadillac Owners Enthusiast
    Apr 2010
    Fleetwood, PA
    36
    825
    Quote Originally Posted by 1madstsv View Post
    Again, modded Cobras are a bad comparison in most cases because they are able to keep IAT's alot lower than we are. They are making great power with less fuel than we can because their lower IAT's result in a much denser charge. If we could cool our incoming air like they can, then we probably would not be having this injector problem at this stage of the game.
    550HP STSV Guest
    I agree. The cobras run so much cooler you cant really compare it. I think may may be one of the hurtles in getting past 420hp with mods and a tune is hurting us.
    jedhead is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V
    Aug 2009
    Orange County, California
    58
    801
    According to my tuner, with the Spectre Intake, I run out of injectors at the 6700rpm.
    Bob
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    I will say its not the injectors stoping us from going past 420 I'm at 418 @ 3700 and only 74% duty cycle when not using meth. So stock you should be able to make 420 at 5300 which is where most cars with out snake bites will be. It's Timmyc not quite having the timeing right our it's the heat making the car pool timeing as in my case. Either way it's not fueling our the a/f would lean way out in the upper rpm,s.
    550HP STSV Guest
    Perfect. This is exactly the info I am looking for. I contacted Steigmeyer, and he said he would do our injectors. since he is not a vendor here, I do not know if I am able to describe pricing and what he would be doing.
  16. #14
    PGA2B's Avatar
    Jun 2009
    USA
    2,661
    Check with Florian, but I thought they were a vendor because of the CTS-V
  17. #15
    550HP STSV Guest
    is this true, florianmod?
  18. Remove Advertisements
