Help! P0011 P0021
Results 1 to 4 of 4
Cadillac STS-V Series Forum Discussion, Help! P0011 P0021 in Cadillac V-Series Forums; I find one bug to squash and it seems another pops up. I know this car has problems from the ...
    GoofyGuy is offline Awaiting Email Confirmation
    Automobile(s): 2006 STS-V
    Oct 2010
    Tampa, FL
    34
    209
    Help! P0011 P0021
    I find one bug to squash and it seems another pops up. I know this car has problems from the shape it was in when I stole it from the auction. I did not buy a warranty due to the fact this car was heavily abused to start with and almost no factory parts are to be found although I tried. I have done a lot of chasing of codes and problems but this one is a bit more tricky.
    P0011 and Im pretty sure its P0021 could be 22 I know they are on the same bank and almost the same description. What do I need to look into on these codes. Where should I start and when I call over to Rippy what do I need?
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    Re: Help! P0011 P0021
    Sounds like a bad cam variator. They bolt to the front of the head.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Cam Position Sensor is my guess. Not sure if you need a CASE learn after changing the sensor.
  5. #4
    Feb 2009
    37
    1,892
    Quote Originally Posted by PGA2B View Post
    Probably more likely than the variator. I'd hook up a good scanner and watch the cam timing, compare cams to see if a sensor is bad.
  6. Remove Advertisements
