Intercooler pump
Results 1 to 3 of 3
Cadillac STS-V Series Forum Discussion, Intercooler pump in Cadillac V-Series Forums; I just got the heat exchanger mounted on my car and ran it for a while but the intercooler pump ...
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    Intercooler pump
    I just got the heat exchanger mounted on my car and ran it for a while but the intercooler pump never came on. Does that only come on at a certain intake air temp or is my pump bad? I want to get my heat exchanger filled up and purged.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Re: Intercooler pump
    The factory setting are:
    Minimum Run time to enable pump is 10 Sec
    Minimum IAT temp is -13*F - Below this temp the Intercooler will be disabled
    Minimum IAT2 temp is 32*F - Below this temp the pump will be disabled.
    The IAT2 is the air temp after the blower in the manifold. So once you start the engine it should run pretty quick. I would check you power to the pump to see if is has juice.
    Feb 2009
    37
    1,892
    I jumpered it to get it purged so I know the pump works. I'll check it with the car running tomorrow but I'm pretty sure it's fine. I was paying more attention to the engine coolant level the first time. The car is done except for the inner fenders in front and the hood. It's getting painted on Monday. I need to adjust one headlight bracket too. Can't wait to start modding.
