Results 1 to 7 of 7
Thread: Coolant Temp Threshold Limits?
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    **EDITED**
    Anyone know what the actual Temp of the low end threshold is? I know we have 180* T-Stats from the factory but wondering what is the actual temp of the cooler threshold is.
    For example..... Since our T-Stat is 180* Factory, would a 160* set a code?
    jmak135 is offline Cadillac Owners Member
    Automobile(s): sts v
    Oct 2010
    42
    40
    Re: Coolant Temp Threshold Limits?
    yes it would the vehicle needs to be at a certan temp to obtain colsed loop u can get that adjusted by having youre car tuned by like a hp tuner software they can adjust the thresholds it will throw a check engine light for to cold for to long
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    No offense, but I am looking for a tech or tuner (like Jesse) to answer the question as we have some running around here. Or someone working at a Dealership.
    I am well versed in tuning and tuning software and know that it can be change with software.
    P.S. Perhaps you noticed I am an authorized Vendor here? I know a few things about cars and tuning. Just wanted a solid answer to the question.
    **EDIT**
    So let me be clear. What is the actual temp that if our car is lower then this temp it will set a code
  5. #4
    Oct 2010
    42
    40
    I am a master technician and own a automotive repair facility .
    DTC p0128 engine started (cold), ECT signal less than 176F at startup, IAT signal more than 20F, engine runtime from 1-22 minutes, MAF signal from 10-35F, vehicle has traveled over 0.5 miles at more than 5 mph, and the ECM detected that the minimum ECT sensor signal of 176F was not met under these conditions.
    This code sets in 2 Trip(s).
    This code will turn on the MIL (Malfunction Indicator Lamp) TO BE CLEAR 176F FOR 2 DRIVE CYCLES.
  6. #5
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    See........THAT is exactally the answer I was looking for. Not some "OLAY" BS with tuning garbage. You can change and tune for almost anything. But stock perameters is what I was looking for. That is why I didn't say anything about "With proper tuning".
    Thank you!!
  7. #6
    Oct 2010
    42
    40
    my pleasure
  8. #7
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Given you experience and knowledge you will be a valuable asset to the community.
  • You may not post replies
