key fob not working
Results 1 to 8 of 8
Cadillac STS-V Series Forum Discussion, key fob not working in Cadillac V-Series Forums; I have to pull on the handle multiple times, and sometimes hit unlock button to get door open. Had trouble ...
    adamhw is offline Cadillac Owners Member
    Automobile(s): STS-V
    Jan 2008
    South Florida
    86
    key fob not working
    I have to pull on the handle multiple times, and sometimes hit unlock button to get door open. Had trouble staring the car once. Worst in am. Took to dealer, they only duplicated it once, so couldn't find the problem. They said it wasn't the battery for the fob. Any ideas? It's getting worse, and I don't want to go back to the dealer and have them not fix it again. Thanks.
    LITTLEELVISDAN's Avatar
    LITTLEELVISDAN is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
    Apr 2007
    Atlanta
    1,777
    Re: key fob not working
    Its the fob battery. I go through them alot. they are cheap and easy to change.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    I would replace the battery and reprogram the FOB to be safe.
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Feb 2007
    Naperville, IL
    393
    does your other fob work OK? If so, it is definitely the battery.
    $4 and 3 minutes of your time to change.
    Bob
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    Yea, CR2032's don't last forever. If worse comes to worse, you have to re-synch them. It is detailed in the owners manual. IT uses that little slot inside the center console (just under the video inputs).
    fast impala is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V, sold to fish!
    Apr 2008
    Gladewater, TX
    114
    LightbulbRe: key fob not working
    Yea, these Fob's are evidently real voltage sensitive. If your automatic trunk release is slow, or won't work, it's probably the battery. They don't seem to last too long.
    Jan 2008
    South Florida
    86
    Thats what I thought, but the dealer said it wasn't the battery. I asked multiple times. I will try other fob, too. Should I just replace the battery and not trust them, that they should of done it?
    jedhead is offline Cadillac Owners Enthusiast
    Aug 2009
    Orange County, California
    58
    801
    The battery is pretty cheap and you will need one sooner or later. I say go for it. If the battery doesn't fix the problem you can store the battery in the freezer for later use.
    Bob
  11. Remove Advertisements
