how to override traction control on the dyno?
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, how to override traction control on the dyno? in Cadillac V-Series Forums; I'm at Speed Inc now trying to dyno the car. It however, won't turn off the traction control no matter ...
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,319
    I'm at Speed Inc now trying to dyno the car. It however, won't turn off the traction control no matter what we do pressing the button.
    TIPS?
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,319
    Re: how to override traction control on the dyno?
    Well we did what we were waiting to do as a last resort, unplug the rear wheel speed sensors
    368.30rwhp & 362.2rwtq
    We're letting it cool a bit to make another run. This thing is running so rich up top, from 5700 - 6200 it dropped from 10.5:1 to off the chart and in the 9's! So leaning this pig out will net huge gains. Wondering if the cats were getting too hot so the PCM was trying to compensate by dumping in more fuel.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Pull the abs fuse that's what I did worked fine and much easer. Let us know on the numbers. Mine made 389rwhp no tq broke the dyno
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    What are u tuning with. If u pull the fuse for the radio it will load the tune faster. It is under the pasanger side rear seat. Do not ask y but it works. Ryan
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,319
    Today wasn't a tune. I just wanted to get a baseline.
    As mentioned above, those AFR's are way out in left field, so it will be tuned here shortly. But before doing that, I'm going to go ahead and do my exhaust and hopefully the intake.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    When you do that it should lean out the car by it's self. I did intake and exhaust on my car and if I had run it to red line it Would have blown up it was so lean. So it may be closer than you think when you re dyno. Good luck and just pull the abs fuse next time much easer. Ryan
    jedhead is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V
    Aug 2009
    Orange County, California
    58
    801
    I didn't gain much peak power between the stock and the tune. The tune is a little richer which gives me a better safety margin. If we had better gas out here in CA, the tune could have been more aggressive in adding spark. I actually lost power with the Wait4Me tune because the engine was pulling timing to prevent knock.
    Bob
    Dynojet Stock vs CAT Tune
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,319
    I know an intake will lean it out some, but not enough to correct this. This is off the charts. From about 4,500rpm on, it's like throwing a rock off a cliff. Take a look;
    550HP STSV Guest
    wow.
    Tinmanx is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V
    Jan 2007
    46
    Where is the ABS fuse located. Today I'm dropping off my 2006 and getting a 2008 so I would definitely like to get my new V dyno'd. Last time we pulled the sensor wires on the rear wheels.
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,319
    IN the electrical center under the rear seat cushion.
  15. Remove Advertisements
