Anyone do an LSx style MAF conversion? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Cadillac STS-V Series Forum Discussion, Anyone do an LSx style MAF conversion? in Cadillac V-Series Forums; Your MAF measures two things, well three if you factor in the IAT's. Otherwise those thermistors in the MAF measure ...
  1. #16
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,312
    Re: Anyone do an LSx style MAF conversion?
    Your MAF measures two things, well three if you factor in the IAT's. Otherwise those thermistors in the MAF measure the volume of the income air, as well as the speed (or velocity) of the incoming air (as PGA mentioned). Generally that is done in Hz.
    Our stock MAF is a drop in module that has a non-aerodynamically friendly chunk of plastic that extends into the center of the airflow. INside this plastic chunk is the thermistors that measure the quantity and speed of the incoming air flow. Ours is very similar to the 3800 V6 engines both N/A and Supercharged.
    Here is ours;
    http://www.autozone.com/autozone/par...er=946992_0_0_
    An LSx style MAF however, is a full bore MAF with an aerodynamic center seperator and has it's thermistors exposed to the income airflow (for more accurate, quicker readings). Most tuners in the country that tune GM V8's do LSx's, and hence are very well experienced in LSx tuning of MAF's.
    Here is an LSx style MAF;
    Hence why I was curious.
  2. #17
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    The LSx style would be better because of the response time but if you have a warranty it will be voided with the change and tuning. I had an LSx style in my GTP. I used a Corvette Throttle Body and MAF on my GTP. You can checkout my cardomain page to see the photos if you would like.
  3. #18
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,312
    That is a concern of mine. ALso once Spectre gets theirs to market, it'll still utilize our stock style setup.
