The ultimate intercooler upgrade! - Page 10
Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 136 to 150 of 185
Like Tree8Likes
Cadillac STS-V Series Forum Discussion, The ultimate intercooler upgrade! in Cadillac V-Series Forums; Here is the only ZR1 kit that I shipped. ZR1 is not ready yet so wiring and water lines did ...
  1. #136
    STS_Chiller's Avatar
    STS_Chiller is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jun 2010
    57
    136
    Re: The ultimate intercooler upgrade!
    Here is the only ZR1 kit that I shipped. ZR1 is not ready yet so wiring and water lines did not ship and not pictured but you can get good idea what is included.
  2. #137
    Automobile(s): None
    Jun 2010
    57
    136
    Bump to view account updates / Don't see them hmmm
  3. #138
    550HP STSV Guest
    Any idea when this will be ready for production?
  5. #139
    Automobile(s): None
    Jun 2010
    57
    136
    Quote Originally Posted by 550HP STSV View Post
    XLR V 2 wks
    ZR1 2wks
    XLR V 2 wks
    ZR1 2wks
  6. #140
    Automobile(s): None
    Jun 2010
    57
    136
    Here are some teaser pictures of GizmoQ car.
  7. #141
    parkeraire's Avatar
    parkeraire is offline Cadillac Owners Fanatic
    Automobile(s): 06' sts-v
    Mar 2011
    Lee Co. FL.
    47
    169
    what is the superheat on that txv set at?
  8. #142
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    The Active InterChiller works as advertised, so far. 78* ambient cruised 20 miles at 70MPH -IC water temp was 127*. Turned chiller on same trip, same speed - IC water temp 44*. Can't wait to start adding timing back in!
    Snake Bit Super Chilled Black Raven 2006 Cadillac XLR-V aka Elwood (Jake's brother)
    Verified 510RWHP and 546TQ so far...final goal 575/550
    ELWOOD - "Corvette in a Tuxedo ... with a Jet Pack"
    2013 St Louis Region SCCA Solo SSM Class Champion
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    ECTA LSR Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
  9. #143
    Automobile(s): None
    Jun 2010
    57
    136
    OMG That’s 83 deg difference!
  10. #144
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,605
    Ok that sounds great but 70mph is far off of wot at 100+mph at 19psi. What I want to know is what is the iat2 temps at speed and wot. when I dynoed my car last week iat2 was 10* higher than outside air temps. And at wot it went up to 155* max. So it was 68* when I dynoed so I want to know what your temps go to under close temps at wot.
  11. #145
    Automobile(s): None
    Jun 2010
    57
    136
    Quote Originally Posted by 1madstsv View Post
    What is your intercooler water temp during above conditions? That’s what will tell you how efficient intercooler is working. If water is hot intercooler is working if water stays near the same then there is no heat transfer. GizmoQ will have more info for you soon. I believe refrigerated water will cool IAT2 better than hot water even on a Northstar.
  12. #146
    GizmoQ's Avatar
    Mar 2007
    St Louis, MO
    2,653
    Did some data logging on the 1100mile trip home. Without the chiller cruising at 84 the modified pump and intercooler surprised me. With no chiller, IC water temp stayed right around 114* (lots of air coming in at that speed). Interestingly, the Active Interchiller at that speed only got the IC water temp down to around 69*. Hmmm. Maybe that was because it wasn't in competition mode (forgot to flip the switch).
  13. #147
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,605
    I do not know what my ic water temp is. Never checked it only iat2 before big fount mount heat exchanger. Iat2 would go to 180-190* in 45* weather now only 155* in 65* weather.
  14. #148
    Automobile(s): None
    Jun 2010
    57
    136
    Quote Originally Posted by GizmoQ View Post
    I would say if AC was good and cold that the blower was making a lot more heat at that speed and intercooler was working well transferring heat to water. We knew going in this would not be as efficient as a Maggie on a LS3 thatís why I increased chiller size 30%. Thatís still around 45deg improvement. We still have the option to try adjusting the Super Chiller Valve. We just plain ran out of time or I would have made 1 more adjustment. Your Freon charge is now 1lb 5oz btw. What about ICWT when youíre stopped and chiller is off how fast does it climb? Your new water tank helps with or without chiller too.
    IMHO youíre big fount mount heat exchanger does not help much when youíre going slow or stopped. Donít forget when AC/Chiller is on heat exchanger is not used. Chiller will keep water cold when stopped going slow or fast air flow is not needed at all.
  15. #149
    GizmoQ's Avatar
    Mar 2007
    St Louis, MO
    2,653
    As soon as I slow down under 50MPH, ICW drops to 41-47* in traffic. When chiller has run for 30 minutes or so and turned off, temps rise back to normal about 30 minutes later. The extra tank makes a big difference. The water in it is cold, the tank is cold, the line to the SC is cold - so the all take a while to warm up. Works great, Dave. Good job on the storage tank.
  16. #150
    rbanshee1 is offline Cadillac Owners Member
    Jan 2012
    99
    Quote Originally Posted by STS_Chiller
    I would like to purchase for my 09 cts v ,please send me your info for ordering,thank you
  17. Remove Advertisements
