Over Aligned?
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Cadillac STS-V Series Forum Discussion, Over Aligned? in Cadillac V-Series Forums; Has anyone seen a specific TSB concerning the inner tire shoulder wear? i was wondering if it gave specific settings ...
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Enthusiast
    Automobile(s): 10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
    Mar 2006
    NC
    574
    Over Aligned?
    Has anyone seen a specific TSB concerning the inner tire shoulder wear? i was wondering if it gave specific settings to eliminate. i had mine done at caddy dealership, and we may have went too far...now the outsides are wearing...
    i know some say it's a firm suspension issue, but others have said it was due to neg camber to help v settle into turns. i think in my case we went to far with camber.
    silverws6ta's Avatar
    silverws6ta is offline Cadillac Owners Fanatic
    Automobile(s): '06 STS-V; '10 STS 1SG; '08 Escalade, '08 Escalade EXT
    Jul 2008
    Spartanburg, SC
    37
    494
    Re: Over Aligned?
    This should be a good median; I don't drive my car very aggressively in turns -- also what tire pressure are you running up front?
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: Over Aligned?
    is that the sts v8 or sts-v? cause i know they are way different.
    thanks ws6
    Jul 2008
    Spartanburg, SC
    37
    494
    Re: Over Aligned?
    Thats from my STS-V -- which is the only baseline the alignment computer has; because there isn't a seperate calibration for our cars; The head tech at my dealer 'tweaks' the settings from factory and this is where he put mine -- No inner/outer wear as of yet on my new set.
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    609
    Re: Over Aligned?
    Thanks for posting the alignement data--just so i understand, the numbers in the pic are the ACTUAL numbers your car is set at,not the Cadillac suggested numbers,right
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: Over Aligned?
    Quote Originally Posted by silverws6ta View Post
    great info! i know you said nothing on this set, but did you have these settings on your last set as well? if so, how did they wear?
    thanks ws6
    Jul 2008
    Spartanburg, SC
    37
    494
    Re: Over Aligned?
    Quote Originally Posted by torched10 View Post
    Correct; those were the ACTUAL settings after the alignment.
    Quote Originally Posted by BMBSALES View Post
    thanks ws6
    The fronts were already worn on the inside from the stock alignment -- but overrall evened out well besides the cupping that was already on the inside. (besides the rears wore in the center) --
    Fronts (especially those with the Pirellis) 33-35lbs is ideal
    Rears (again - especially those with Pirellis) 28-30lbs is ideal
    That will keep the fronts wearing evenly, and not just on the edge, and the rears will wear evenly, and not just in the center.
    cadillac94pimpin is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Brougham,06 STS-V Black/Tango, 06 Hayabusa LE
    Oct 2009
    Delray Beach/Plam Beach Florid
    31
    175
    Re: Over Aligned?
    I just had my algnment done at my friends Frestone store. They had just recieved a huge software update recently for there alignment machine. It now has anlignment specsfor the STS-V. It definetley varies from the standard STS specs. I will see if I can get a print out or something with what they had in there for it. I am very happy with it so far. With hankooks I just put all the way around.
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: Over Aligned?
    Quote Originally Posted by cadillac94pimpin View Post
    Def post up if you can, so we can see the differences if any
    i was wearing inside shoulder bad, but with align it has now turned to outside shoulder, but worse on passanger side...with pilot sport a/s
    Jul 2008
    Spartanburg, SC
    37
    494
    Re: Over Aligned?
    If you go more than -.5 camber (as in more toward neutral 0.0) I'm sure you will get that -- although many say CASTER should not affect wear, I wouldn't advise more than .5 degree difference on the passenger side on any vehicle to compensate for road crown.
    I'm not an alignment guru, but my WS6 used to eat up some tires on the front - the factory specs were crap; and after trial and error they wear very evenly now.
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: Over Aligned?
    i may have to check on mine again and see where i'm at.
    i mostly drive in left lane of freeway, so i'm not as big a fan of setting up for crown...
    paranoid1123 is offline Cadillac Owners Member
    Automobile(s): '05 c6 MN6 '06 STS-V
    Jan 2009
    Houston TX
    37
    37
    Re: Over Aligned?
    I know this is an old post but.... Any info?
    550HP STSV Guest
    Re: Over Aligned?
    same. i have my specs and want to compare.
  16. #14
    Oct 2009
    31
    175
    Re: Over Aligned?
    My buddy just moved. I will see if the new firestone he works at has the STS-V in there alignment software.
  17. #15
    Jan 2009
    Houston TX
    37
    37
    Thanks that will be great.
  18. Remove Advertisements
