Crank relearn instructions with and without a scan tool
Results 1 to 5 of 5
Cadillac STS-V Series Forum Discussion, Crank relearn instructions with and without a scan tool in Cadillac V-Series Forums; ...
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    [B]To perform the relearn, proceed as follows:
    Connect a scan tool to make sure there are no trouble codes stored in the computer’s memory. If there is any power train trouble code other than P1336 (Crankshaft Position Variation not learned), the computer will disable the relearn function until the problem that caused the code has been eliminated. Also, make sure that the engine coolant (check it when the engine is cold) and oil levels are at an acceptable level.
    1. Set the parking brake and block the drive wheels. Make sure that the hood is closed.
    2. Start the engine and make sure that the engine coolant temperature is at least 158 degrees F. (70 degrees C.)
    3. Turn the engine off for at least 10 seconds.
    4. Select the crankshaft position variation learn procedure (CASE Learn)on your scan tool.
    5. Make sure that the transmission is in Park. Start the engine.
    6. Apply the brakes and hold the pedal firmly.
    7. Follow the scan tool instructions.
    Remember: That you are going to increase the engine speed to approximately 3000 RPM, 4000 RPM, or 5150 RPM. That’s the variation learn fuel cutoff RPM (depending upon the engine), and that it’s important to release the throttle when the engine RPM starts to decrease as a result of the fuel cutoff going into effect. Failure to do such will result in over revving of the engine, causing possible engine damage.
    8. Once the engine has returned to idle, check the status of Diagnostic trouble code P1336. If the scan tool indicates that the CASE has been learned, the relearn procedure is now complete. If CASE has not been learned, check for the presence of other power train codes. If any exist, correct the problem, then repeat this procedure.
    NOTE: If the Crankshaft Variation Relearn is not accessible through your scan tool (some truck applications 1998 & later), perform the relearn in the following manner:
    1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
    2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
    3. Cruise at 55 mph for another 5-6 minutes.
    4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
    5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
    6. Accelerate to 55 mph and cruise for 2 minutes.
    7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.) with the clutch depressed.[/
    B]
    LITTLEELVISDAN's Avatar
    LITTLEELVISDAN is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
    Apr 2007
    Atlanta
    1,777
    Re: Crank relearn instructions with and without a scan tool
    HPTuner people here is the window for us,
    Bee iLL's Avatar
    Bee iLL is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Raven Black STS-V, 2010 Radiant Silver SRX Premium 2.8T
    Apr 2007
    Chicago
    33
    470
    Those of you that have done the crank relearn on the STS-V, what is the RPM for fuel cutoff? 3000 RPM, 4000 RPM, or 5150 RPM?
    WillySTS is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Feb 2006
    Los Angeles
    64
    627
    I think it was 4400 or somewhere like that. You know its different in neutral than while driving and the tach swings so fast the needle
    over shoots the actual cut off.
    maj372169 is offline Cadillac Owners Member
    Dec 2013
    1
    WAIT4ME, Thank you for the information on CASE relearn (in red text) i have a scan tool but not with relearn capabilities, i was searching and searching on the internet until i found this god sending information (ok i maybe exaggerating) that you had posted back in "09". My problem is that i have a "98" chevy c1500 (this is the reason why I'm so grateful for your knowledge) and I live in L.A. CA. My question to you is can I perform this procedure on some heavy duty jack stands, chalk block the front wheels OR do I need to wait till 3:00 am sunday morning (NO TRAFFIC) because i need the load of the truck to properly set the parameters
  8. Remove Advertisements
