Tranny issue?
Results 1 to 9 of 9
Cadillac STS-V Series Forum Discussion, Tranny issue? in Cadillac V-Series Forums; I've got a little irritating tranny issue. I purchased my V new, in May. Every now and then, usually on ...
    fast impala is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V, sold to fish!
    Apr 2008
    Gladewater, TX
    114
    QuestionTranny issue?
    I've got a little irritating tranny issue. I purchased my V new, in May. Every now and then, usually on a cold start, it will hesitate, when you make a slow, coasting, sharp, right-hand turn. It doesn't die, just add some throttle, and it drives fine. If you keep throttle, and don't coast, it doesn't do it. No CEL's, and only under those conditions. It will do it in D, and SD. It doesn't do it in manual shift mode. It is very intermittent.
    The very first time it did it, the car was less than two weeks old. I was coasting through a right-hand turn, uphill, and the car just wouldn't go. No CEL, didn't die, just no power. I turned the car off, put it in park, and it drove fine, after that.
    I mentioned this to the dealer, when I went in to get my plates. They hadn't had any problems like this, of course, they've only sold two of them.
    It almost seems like the PCM isn't telling the tranny what gear to select, or maybe the fly-by-wire throttle has some little gremlin.
    It's not a real issue, just a little irritating.
    Anyone have any thoughts or similar experience?
    TIA
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Re: Tranny issue?
    What year is this STS-V, 08? You might want to make sure they have all the latest updates on your V as GM is constantly putting out software updates for these vehicles. As your service advisor to look into this. He can pull the history through the VIN#. Besides your dealership should be all over this issue, even if they have only sold 2...
    Good luck.
    Dr. Design
    Quote Originally Posted by fast impala View Post
    TIA
    LITTLEELVISDAN's Avatar
    LITTLEELVISDAN is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
    Apr 2007
    Atlanta
    1,777
    Re: Tranny issue?
    unplug your pos + battery cable and leave off for 30 min.... reconnect ... see if problem goes away. this will reset your PCM/ECM. These suckers are smart, they remember your driving habbits and adjust accordingly.
    Everytime I leave my house, I back out then pull forward on a down hill slope. The trans eventually learns this patters and starts leaving it out of gear until you apply 1/4 throttle to engage the gear twords the bottom of the hill. Thus making the car lurch forward. resetting the ECM clears it up. I then started doing more random things while leaving the house as not to build up a pattern.
    You may have done the same thing early on and it still remembers. Clear it out and see if that fixes it.
    Apr 2007
    Atlanta
    1,777
    Re: Tranny issue?
    AND if you are having problems with your tranny go buy her something new. You have got to treat your tranny right.......
    I'll be here all week folks....
    don't forget to tip your serving staff..
    Apr 2008
    Gladewater, TX
    114
    Thumbs upRe: Tranny issue?
    Thanks for the tip, I think it is software related. I specifically asked them to check for updates, when I bought the car. It was built in October of 07.
    This is a good dealership, but I kinda got the "deer in the headlights" look when I mentioned re-flashing it. Their tranny guy had not heard of anything like I described.
    Plus, I've got a D3 package on it now, and it did it before I did the "mod" stuff.
    I race an EFI car, so I'm fairly saavy on a lot of stuff. I knew the computer would do some learning, and maybe it picked up some habit of mine.
    I go down and uphill to the right, every time I leave my house.
    Apr 2008
    Gladewater, TX
    114
    QuestionRe: Tranny issue?
    One more thing, are there any issues to just disconnecting the battery? Seems I saw somewhere, where somebody had issues with maybe the radio or some other stuff, when doing it?
    Apr 2007
    Atlanta
    1,777
    Re: Tranny issue?
    Nope, you are good as long as you don't do it for a month. I do mine about once every other month and I haven't lost any presets
    Apr 2008
    Gladewater, TX
    114
    Thanks,
    I'll definitely give it a try!
    Apr 2008
    Gladewater, TX
    114
    Well, it worked! I disconnected the battery for thirty minutes, and the right-hand turn stutter is gone. It also seems to drive better. I did baby it a bit, when I first got the V.
    After I re-connected the battery, I went out did some spirited driving, especially in right-hand turns!
    I was surprised to find out, that when I disconnected the battery, it locked all the doors!
    Thanks again, for the tip!
  12. Remove Advertisements
