| Re: Oil Leak Between Engine and Transmission... You know after looking closely at your pictures, it looks like the oil is coming from the crank. If you look, the filter is 90 degrees away from your oil buildup, plus you can see it coming down the pan. I don't know how the heck the filter 5" over and on another side could cause that oil leak, when you get your car back check it again please.
I don't want to say that they are just blowing you off, but it has known to happen, and again like I said it looks from the crank not the filter!
It isn't that hard for them to replace the seal, especially with how the block is setup on this car. The pan being a forged aluminum pan, its real easy to take off and put back on, so getting to that last endcap is pretty easy. I am pretty sure that it is a split seal that these engines use wich means they should be able replace them without having to pull the tranny or motor like on some cars! |
