STS-V Dyno Tune
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, STS-V Dyno Tune in Cadillac V-Series Forums; Jeremy Formato dyno tuned the STS-V today; this was his first time with an STS-V on a dyno, and the ...
    MLV's Avatar
    MLV
    MLV is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS-V, Maggied '05 CTS-V, '07 STS-V
    Nov 2004
    Gainesville, FL
    68
    289
    STS-V Dyno Tune
    Jeremy Formato dyno tuned the STS-V today; this was his first time with an STS-V on a dyno, and the results were excellent. He made many adjustments that are beyond my ability to explain, but throttle response is better, shifting faster and there's noticeably more power. There was a gain of about 38 hp and 18 lb ft of torque. On top of that, he's a very nice guy and very conscientious. I had a great time tonight burning rubber like a 16 year old.
    Slo-Mo-Shun's Avatar
    Slo-Mo-Shun is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V; TopKart Flash 125 Shifter
    Jan 2008
    161
    Re: STS-V Dyno Tune
    Apparently you won't be posting on the thread complaining about the gas mileage?
    MLV's Avatar
    MLV
    Nov 2004
    Gainesville, FL
    68
    289
    Re: STS-V Dyno Tune
    Nope.
    LITTLEELVISDAN's Avatar
    LITTLEELVISDAN is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
    Apr 2007
    Atlanta
    1,777
    Re: STS-V Dyno Tune
    UM there is something seriously wrong with the dyno. How did he make 1185.10 Ft lbs of TQ? That's the TQ of a twin turbo racing diesel.
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    Re: STS-V Dyno Tune
    Quote Originally Posted by MLV View Post
    As to our earlier PM conversation... I am not sure why he chose to do the dyno runs in 3rd gear?? It's not the closest to 1:1 ratio.. Maybe someone else can chime in on this one.
    1st Gear Ratio 4.027
    2nd Gear Ratio 2.364
    >3rd Gear Ratio 1.532
    4th Gear Ratio 1.152
    5th Gear Ratio 0.852
    6th Gear Ratio 0.667
    Reverse Ratio 3.064
    CIWS's Avatar
    CIWS is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
    Dec 2005
    D/FW Tejas
    25,514
    Re: STS-V Dyno Tune
    Take it back, have him flash it back to stock. Then do a couple of pulls in 4th at stock, then flash back to your final tune and do a 3rd pull. Make sure he shows you SAE numbers vs STD. You've got a couple of funky things there as others pointed out.
    NormV is offline Cadillac Owners Connoisseur
    Automobile(s): XTS VSport-550+ lb-ft of torque, ATS 2.0T AWD HPTuners tuned
    Jun 2007
    OH-IO!
    2,643
    Re: STS-V Dyno Tune
    Quote Originally Posted by =LITTLEELVISDAN View Post
    Tachometer reading from the sparkplug wire?
    Norm
    MLV's Avatar
    MLV
    Nov 2004
    Gainesville, FL
    68
    289
    Re: STS-V Dyno Tune
    I don't know what caused the torque spike in the first run. The computer gave a reading of 348 lb ft as I recall. Whether done in 3rd or 4th, the gain would appear to be more important than the absolute number. At any rate I'm happy with the final result.
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Re: STS-V Dyno Tune
    Quote Originally Posted by NormV View Post
    Norm
    Spark plug wire on an STS-V ?
    Apr 2007
    Atlanta
    1,777
    Re: STS-V Dyno Tune
    I'm not knocking your tune. I am just having fun with the dyno. I believe in re-tuning as my gains have greatly changed the performance of the car. Wasted a C6, and kept up door to door with a lowered and cat back modified C6 Z06. All with only a tune and TQ nanny removal. Got a thumbs up from both Vette drivers
    MLV's Avatar
    MLV
    Nov 2004
    Gainesville, FL
    68
    289
    Re: STS-V Dyno Tune
    Norm
    That's possible; they tried a couple of different connections, I think. Would that cause an aberration in the torque reading?
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Re: STS-V Dyno Tune
    The STS-V doesn't have spark plug wires. It uses coil packs that directly fit over the spark plug. Now it's possible to take the lead from the dyno, clip onto a coil pack and get enough inductance to have an rpm reading for the dyno. What they probably did was move the lead around looking for a signal until they found it.
    I still think you should get them to give you the SAE numbers from the runs as well as the STD ones though. They can do that from the runs already completed.
  15. Remove Advertisements
