Wiper Blade Replacement - Page 2
Results 16 to 30 of 36
Like Tree6Likes
Cadillac STS-V Series Forum Discussion, Wiper Blade Replacement in Cadillac V-Series Forums; Yea, I found that out after I lifted the passenger side to replace my blades. It pissed me off because ...
  1. #16
    kbf250 is offline Cadillac Owners Member
    Automobile(s): 06 STS-V
    May 2010
    60
    82
    Re: Wiper Blade Replacement
    It pissed me off because it chipped the paint on the edge of the hood. So I
    pulled the whole arm and moved it two teeth on the spline so that I can lift
    blade when I wash the car. Back on topic I replaced mine with Rainx and they aren't
    any more difficult than any other car. Rainx is sold at most auto parts.
    Kirk
  2. #17
    May 2010
    60
    82
    Quote Originally Posted by ssstealth View Post
    IMPORTANT - See TSB 886153 - Wiper blade must be in mid travel position before changing. Otherwise, the passenger side arm will scrape the hood.
    Part Numbers for the blades are:
    88958361
    88958359
    List is $29 each, $15 from http://www.gmpartsdirect.com/
    Kirk
  3. #18
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    583
    i know this is an old one but i need blades for my 2008 and i tried to find the tsb 886153 referenced and couldnt find it
  5. #19
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Also, remember that the wipers will park if you open the hood. If you have the wipers in change position, or are in the middle of the process, that could cause some damage you have anything in the area,or for some reason the wiper arm against the glass with no towel under it.
  6. #20
    willits's Avatar
    willits is offline Cadillac Owners Member
    Automobile(s): 1958 Coupe DeVille, 1961 Series 62 Convertible, 2008 STS-V
    Jul 2008
    Prague, Czech Republic
    27
    I have Goodyear blades on mine. I believe the part numbers are just how long they are. In the case of the V - 22"
    http://www.goodyearwiperblade.com/?mid=CADILLAC
    Peter
  7. #21
    jhawkmille's Avatar
    jhawkmille is offline Cadillac Owners Member
    Automobile(s): sts-v
    Feb 2011
    Olathe, KS
    4
    My dealer had exact replacements, cost me $24 for both. Originally bought bosch but they are not as low a profile so called dealer for giggles and they had them in stock and where $3 cheaper per.
  8. #22
    neurotictim is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V mostly stock
    Jun 2011
    Virginia Beach, VA
    461
    Another zombie resurgence, but I can say safely that Bosch Icon will NOT fit my 06. The mechanism will only accept small hook, large hook, and pin-style wipers. Ours, not so much.
    :EDIT:
    Okay, so I went back to Pep Boys and took another shot at it, and Bosch Icon will fit - the difference is that you need to make sure the Icons you get are the "24 OE" and "21 OE" models. They take a second to figure out but snap right in once you've got it.
  9. #23
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    Sep 2010
    277
    I bought OE replacements from rock auto for $3.60 each. Snapped right in, wipe clear. Nice way to save $45.
  10. #24
    choigilligan is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Aug 2010
    195
    I just mine at Costco when they go on sale. They're Goodyear. I think it's like 6 or 7 bucks each blade. They fit and work well.
  11. #25
    GMTURBO Guest
    I bought the Goodyear Costco ones as well but haven't installed them. Good to hear they'll fit.
  12. #26
    paul427 is offline Cadillac Owners Member
    Automobile(s): STS V
    Aug 2013
    Miami FL
    34
    Wow I spent almost $60.00 on my replacement blades.
  13. #27
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,313
    I have the Bosch Icon 21OE and 24OE. It takes two minutes to R&R. These are not the standard style, but I had worked on these before, so I did have some familiarity with them. But the Bosch's literally snap into place.
    Like everyone, I have the issue with the passenger arm contacting the hood, but the hood has already been scratched from contact, but what I do, is gently pull the wiper arm towards the top of the windshield, then pull it away from the windshield. On either side of the arm, are two finger clips. Squeeze them and push the blade away from the arm, tilting it a little at the end (so it unhooks).
    The Bosch's have a little plastic piece on them that you don't need. Use the push tab on the top of that plastic piece and pop it off. From there, take the blade over to the arm, hook it on the end, and lock the new blade's finger clips into the arm. DONE.
    neurotictim and Guy.Seminerio like this.
  14. #28
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    I use the same blades. Once I realized there was that throwaway plastic piece it was smooth sailing.
  15. #29
    Sep 2010
    277
    I actually had a crap fitment with those Goodyear blades, and they chattered while wiping...likewise for my dad on a Toyota Avalon. Guess we were doing something wrong???
    Like Father, like Son
  16. #30
    Feb 2013
    Whitestone, NY
    28
    3,211
    I'm referring to the Bosch.
  17. Remove Advertisements
