~Made the move to a 2006 STS-V today~ - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Cadillac STS-V Series Forum Discussion, ~Made the move to a 2006 STS-V today~ in Cadillac V-Series Forums; Originally Posted by Slo-Mo-Shun Big rear wing, coffee can muffler with 5" outlet, neon undercarriage lights? Or maybe spring for ...
  1. #16
    Berger 93 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS-V
    Feb 2007
    Schaumburg, IL
    317
    Re: ~Made the move to a 2006 STS-V today~
    Quote Originally Posted by Slo-Mo-Shun View Post
    Big rear wing, coffee can muffler with 5" outlet, neon undercarriage lights? Or maybe spring for the big mod: Lambo doors!
    YUP! Man, I cannot type . . . LOL . . . Rice
    I am going to guess I ment DRIVE . . .
  2. #17
    pjbizjak is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 07 STS w/1SG Pkg
    Nov 2007
    N.E. Ohio
    345
    Check the tires.......@ 11K they're probably half gone.
  3. #18
    Slo-Mo-Shun's Avatar
    Slo-Mo-Shun is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V; TopKart Flash 125 Shifter
    Jan 2008
    161
    Quote Originally Posted by austin View Post
    Thanks.. I mentioned i wanted the nav & the main computer flashed to the most recent firmware and they said no problem. I forgot about the differential seal. Should i request anything else while it is there??
    Not a dealer thing, but you should be "grandfathered" into the free Nav disk update program. Get your VIN number and call 1-877-NAV-DISC (1-877-628-3472) to order a 2008 disc set. I just did it for my 2006 today.
  5. #19
    CIWS's Avatar
    CIWS is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
    Dec 2005
    D/FW Tejas
    25,514
    Hey alright, POINTS to you (if we still had Points).
    2008 NAV DISC CORV/GP/STS/9-5 (North America) for 2006 CADILLAC STS
    Unit price: $0.00, Qty: 1, Cost: $0.00
  6. #20
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    You must be a mind reader! I was just thinking the other day of how i could get an upgraded disc, as i saw that the GM NAV Upgrade website wanted a special invitation number to be entered (which i don't have). So,,, i'm thinking where do i get that from? But, you think just a telephone call and vin number is all i need?? I hope so, as that would be great... Unless it is only good for the 1st owner??
  7. #21
    Jan 2008
    161
    I am not the first owner. I called because when I tried to update the owner info, the website told me I had a 2006 Buick Terraza (ugh!). So I called to correct that. While I had a rep on the line, I asked if I was entitled to a free update and she said "yes" and took my order.
  8. #22
    VelocitySTSV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS V '06
    Mar 2007
    Chicago
    39
    129
    See if they can upgrade the radio controls to the steering wheel.
    In 2007 they corrected the small issue- in 2006 when you hit the channel search button, it seeks all chanels rather than the preprogramed ones. The 2007 has 2 funtions on the button rather than just 1. They did this to correct the issue.
    My dealer couldn't figure it out.
  9. #23
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I don't see many issues on STS-V.
    There were some enahancements to the ECM programming, good idea to get the latest software put in.
    The radio update is a must, make sure they follow the TSB steps carefully.
    I have seen a few wiring issues, the engine harness is kind of strange. I won't bore you with those details.
    I have 2 that come in regularly... until I get them, then they stay gone until they need another oil change
    I think you will really love the car. I really like them.
  10. #24
    austin's Avatar
    Apr 2005
    Boston, MA
    1,749
    Quote Originally Posted by ewill3rd View Post
    Would you happen to have some sort of referance to show that a ecm upgrade exist (like the nav one), or perhaps a version number, or a document number that i can tell them where to look it up.... Just so that i can show them is does exist, and that i know what i'm talking about. Thanks..
  11. #25
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Usually I just check by doing the reprogram, if the cals haven't been updated it will not let me proceed with programming but show me a "GM does not recommend programming with the same calibrations".
    Here is one:
    Subject: LC3 Engine MIL/SES, DTCs P0128, P0171, P0174 or P2261 (Reprogram ECM) #06-06-04-053 - (10/16/2006)
    Models: 2006 Cadillac STS-V, XLR-V
    with Supercharged 4.4L Northstar® DOHC V8 SC Engine (VIN D -- RPO LC3)
    Condition
    Some customers may comment on an illumination of the SES/MIL with no other symptoms. Upon further investigation, the technician may find one or more of the following DTCs stored in the ECM:
    • DTC P0128: Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
    • DTC P0171: Fuel Trim System Lean Bank 1
    • DTC P0174: Fuel Trim System Lean Bank 2
    • DTC P2261: Supercharger By-Pass Valve Stuck
    Here is one for the TCM:
    Subject: 5L40-E/5L50-E Transmission Torque Converter Clutch (TCC) Surge, Shudder, Exhaust Moan, Chuggle Noise at Low Speed and Light Load (Reprogram TCM) #06-07-30-030A - (09/05/2007)
    Models: 2004-2007 Cadillac CTS
    2005-2007 SRX, STS
    with V6 Engine (VIN Codes 7, N, T -- RPOs LY7, LA3, LP1)
    2004-2006 SRX
    2005-2006 Cadillac STS
    with V8 Engine (VIN Code A -- RPO LH2)
    This bulletin is being revised to add V6 engine applications. Please discard Corporate Bulletin Number 06-07-30-030 (Section 07 -- Transaxle/Transmission)
    Condition
    Some customers may comment on a shudder, surge or chuggle on light throttle under light load just after torque converter clutch (TCC) engagement. Others may comment on an engine exhaust moan in the 1200 RPM range between 65-73 km/h (40-45 mph). This occurs with the transmission at normal operating temperature and commanding the TCC off with the scan tool will eliminate the concern.
    Also there are two recalls on some vehicles for reprogramming the ECM.
    Give me (or PM me) the last 8 of the VIN and I'll run it for you to see if there are any open recalls... or have them check.
  12. #26
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Mine came today, actually two disks this time US/Canada West and US/Canada East. It shows as version 4.00 GM p/n 25852830U.
    Backing them up to an image file now
    Thanks for the head's up Slo-Mo-Shun.
  13. Remove Advertisements
