Cadillac STS-V Series Forum Forum specifically for Cadillac STS-V series discussions.
 | Cadillac Forums: What is the Difference between a 2006 / 2007 STS-V??
02-08-08, 11:20 PM
|  | Cadillac Owners Connoisseur Cadillac(s): ~2004 CTS-V, 2006 STS-V, 2007 Escalade~ | | Join Date: Apr 2005 Location: Boston, MA | | | What is the Difference between a 2006 / 2007 STS-V?? Hi,
Since manufacturers usually tweak there cars after the initial launch (often refered to as getting the bugs out). Can someone tell me what is the difference (however slight it may be) between a 2006 STS-V, and 2007 STS-V??
Thanks.  |
02-09-08, 06:43 AM
| | Banned | | | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Quote:
Thanks.  | Austin,
as far as I know they did delete the "stealth gray" for 07 and replaced it with "thunder gray".
Now for 08 they come with HUD.
Harry |
02-09-08, 07:41 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 78 Eldo,78 Toronado XS,06 STS4,06 STS-V,07 GMC Sierra SLT | | Join Date: Mar 2005 Location: Cary, NC Age: 38 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? The only difference I am aware of is that on the 06, the radio up/down button on the steering wheel just does a scan up and down on the 06. On the 07 it scans one way (up I think), but does a preset scan if you push the other direction. |
02-09-08, 10:58 AM
|  | Cadillac Owners Connoisseur Cadillac(s): ~2004 CTS-V, 2006 STS-V, 2007 Escalade~ | | Join Date: Apr 2005 Location: Boston, MA | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Oh.. Thanks guys. I couldn't find anything in the faq... Actually the faq. is looking rather thin for the STS-V. Hopefully that will change.  |
02-09-08, 11:07 AM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Well it's up to us to populate it  |
02-09-08, 01:54 PM
|  | Cadillac Owners Fanatic Cadillac(s): 07 EXT, 06 STS-V, 06 C6, YAM R1 | | Join Date: Mar 2006 Location: NC | | | Re: What is the Difference between a 2006 / 2007 STS-V?? i noticed some bug type changes in the ecm programming between the 06 file, and the 07 file. |
03-12-08, 04:12 PM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2003 Location: Alexandria, VA Age: 27 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? 08 models are the only ones with hud added to it? |
03-12-08, 05:56 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Quote:
Originally Posted by Devil_concours 08 models are the only ones with hud added to it? | So far yes. The 08 gains HUD, Lane departure, and blind spot warning (besides side vents). |
03-12-08, 06:25 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 78 Eldo,78 Toronado XS,06 STS4,06 STS-V,07 GMC Sierra SLT | | Join Date: Mar 2005 Location: Cary, NC Age: 38 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? The 08's also have way more "brushed aluminum" on the dash around the radio stack in place of the completely wood panels in the 06-07's. |
03-13-08, 03:21 AM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2003 Location: Alexandria, VA Age: 27 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? what about the keyfob?
Did they switch over to the new keyfob for 07 or 08? |
03-13-08, 04:59 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 06 STS-V | | Join Date: Apr 2007 Location: Atlanta Age: 42 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? so can you load a 07 ECM program on to an 06? to fix the bugs then tune from there? |
03-13-08, 06:00 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: What is the Difference between a 2006 / 2007 STS-V?? You got bugs in your ECM LITTLEELVISDAN ?  |
03-15-08, 10:18 AM
|  | Cadillac Owners Connoisseur Cadillac(s): ~2004 CTS-V, 2006 STS-V, 2007 Escalade~ | | Join Date: Apr 2005 Location: Boston, MA | | | Re: What is the Difference between a 2006 / 2007 STS-V?? If you havn't done this yet.... You should take your "2006 STS-V" in for the latest computer software update. You can referance this bulitin to get it done under warranty.
Here is the TSB number;
(Reprogram ECM) #06-06-04-053 - (10/16/2006)
Models: 2006 Cadillac STS-V, XLR-V
with Supercharged 4.4L NorthstarŽ DOHC V8 SC Engine (VIN D -- RPO LC3) |
03-16-08, 01:12 AM
| | Cadillac Owners Connoisseur Cadillac(s): Sedan de Ville, CTS | | Join Date: Mar 2007 Location: San Antonio, Tx | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Warranty and about $1000 or so. |
03-16-08, 11:48 AM
|  | Cadillac Owners Connoisseur Cadillac(s): '93 Fleetwood Brougham...Dad's | | Join Date: Jul 2003 Location: Southern DE Age: 23 | | | Re: What is the Difference between a 2006 / 2007 STS-V?? Quote:
Originally Posted by Devil_concours what about the keyfob?
Did they switch over to the new keyfob for 07 or 08? | 2008 only, and onward. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
