Recall 07204 - Is on the GM VIS
Results 1 to 10 of 10
Cadillac STS-V Series Forum Discussion, Recall 07204 - Is on the GM VIS in Cadillac V-Series Forums; The Recall is official to the dealers now, you should recieve your letters soon. I pulled up my own car ...
    WillySTS is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Feb 2006
    Los Angeles
    64
    627
    I pulled up my own car on the VIS and it lists the recall # as open(not done), but in the desciption it says N/A...maybe it's still to soon.
    Anyway, this is just a FYI.
    Slo-Mo-Shun's Avatar
    Slo-Mo-Shun is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V; TopKart Flash 125 Shifter
    Jan 2008
    161
    Re: Recall 07204 - Is on the GM VIS
    Pardon my ignorance, but the recall pertains to what part/condition?
    CIWS's Avatar
    CIWS is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
    Dec 2005
    D/FW Tejas
    25,514
    Pinion seal on the diff, (it should be) several GM models are subject to it.
    edit- news.
    http://deseretnews.com/dn/view/0,5143,695238794,00.html
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Here is the first part of the recall:
    Subject: Product Safety - Drive Axle Seal Leak-Replace Seal #07204 - (01/31/2008)
    Models: 2005-2007 Cadillac CTS, CTS-V, SRX, STS
    2006-2007 Cadillac STS-V
    2007 Daewoo G2X
    2007 Opel GT
    2006-2007 Pontiac Solstice
    2007 Saturn SKY
    Condition
    General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles. The drive axle differential seal (two on all-wheel drive vehicles) may leak because it does not meet GM's specifications. If a seal is leaking, there will be fluid on the ground where the vehicle is parked. If enough fluid leaks, the differential will become noisier because of reduced lubrication. After about two-thirds of the differential fluid is lost, the bearings may no longer be lubricated and may start to overheat. Damage to the bearings and other differential components could then occur. Damaged bearings will create noise that may be heard by the vehicle occupants. If the vehicle is not repaired and damage progresses, three conditions can occur: (1) When the vehicle is stopped and shifted to reverse, the differential may jam and prevent vehicle movement; (2) the damage can cause drag that will feel like the brake is applied; or (3) the differential could jam and lock the drive wheels while the vehicle is in motion. If (3) occurs, the driver may not be able to control the vehicle and a crash could occur without warning.
    Correction
    Dealers/retailers are to install a new drive axle differential seal (two on all-wheel drive vehicles).
    Vehicles Involved
    Involved are certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles built within these VIN breakpoints:
    Year
    Division
    Model
    From
    Through
    2005
    CTS
    50207119
    50237751
    2006
    CTS
    60100001
    60213969
    2007
    CTS
    70100002
    70198445
    2005
    CTS-V
    50207126
    50234392
    2006
    CTS-V
    60102809
    60209495
    2007
    CTS-V
    70100001
    70197204
    2005
    SRX
    50207077
    50237338
    2006
    SRX
    60100011
    60222963
    2007
    SRX
    70105009
    70193999
    2005
    STS
    50207130
    50237744
    2006
    STS
    60100019
    60222184
    2007
    STS
    70100056
    70197027
    2006
    STS-V
    60104156
    60217940
    2007
    STS-V
    70100060
    70195959
    2007
    Daewoo
    G2X
    7Y136494
    7Y140874
    2007
    Opel
    GT
    7Y111678
    7Y142685
    2006
    Pontiac
    Solstice
    6Y000001
    6Y120195
    2007
    Pontiac
    Solstice
    7Y103375
    7Y142882
    2007
    Saturn
    SKY
    7Y100001
    7Y142740
    Important: Dealers/retailers are to confirm vehicle eligibility prior to beginning repairs by using the system(s) below. Not all vehicles within the above breakpoints may be involved.
    -- GM dealers and Canadian Saturn retailers should use GMVIS.
    thefred's Avatar
    thefred is offline Cadillac Owners Enthusiast
    Sep 2004
    Atlanta, GA
    817
    Wow, I just checked my service history and my dealer did this repair on December 4! Good for them, they fixed it even before the recall. But, I recall them telling me they saw it leaking so they fixed it. Still, they found something I didn't specifically ask them to fix, so they get points from me!
    jtcarlson is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V
    Dec 2007
    Miami
    39
    9
    I see they are only listing up to 2007. I take it this issue was fixed with a 2008 STS-V? Should I check this for my 08?
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    '08 is completely different.
    fred, the new design seal wasn't available until December 17th to my knowledge.
    They may have replaced the seal but I wouldn't bet that it has the new design.
    If the recall applies I'd have them inspect it to verify it has the new design seal.
    thefred's Avatar
    Sep 2004
    Atlanta, GA
    817
    Quote Originally Posted by ewill3rd View Post
    Interesting. Thanks Bill. Is there a new part number? Maybe I could check my invoice for it....
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I posted them somewhere else, but I'll get it and post them here too. If it doesn't have one of these part numbers then it has the old design seal.
    Part Number
    Description
    Qty/ Vehicle
    19179933
    Seal Kit, Diff Drv P/Gr (CTS, STS, SRX, Solstice, SKY, GT) (Note: STS AWD & SRX AWD will also require P/N 19179936)
    1
    19179934
    Seal Kit, Diff Drv P/Gr (STS-V, CTS-V)
    1
    19179936
    Seal Kit, Frt Diff Drv P/Gr (STS AWD, SRX AWD) (Note: STS AWD & SRX AWD will also require P/N 19179933)
    1
    89021677 - US
    89021678 - CN
    Lubricant, Gr Synthetic, SAE 75W-90
    1-2 (as needed)
    01052358 - US
    00992694 - CN
    Lubricant, Limited-Slip Differential
    1 (if needed)
    Berger 93 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS-V
    Feb 2007
    Schaumburg, IL
    317
    My notice came in the mail on Sunday . . .
  13. Remove Advertisements
