Results 1 to 7 of 7
Thread: Head gasket question
    Slo-Mo-Shun's Avatar
    Slo-Mo-Shun is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V; TopKart Flash 125 Shifter
    Jan 2008
    161
    After perusing the technical forum and seeing a 20-mile-long thread on Northstar head gasket and head bolt issues, I started wondering about the STS-V.
    It appears to me that at least part of the Northstar head gasket problem might be with the gasket itself, which appears to fail after 80-100,000 miles of trying to maintain a seal against the high expansion coefficients of an all-aluminum engine.
    In the recent Car & Driver, it is mentioned that the new, supercharged 'vette ZR-1 has a 4-layer gasket rather than a 2-layer gasket to help cope with the stress.
    Anyway, I'm wondering if Cadillac did a similar upgrade on the Northstar in the STS-V? I know they reduced the bore to make the block stronger. Coming up with a whole new set of pistons and new block casting is pretty hard core. The resized block would need a resized gasket anyway, so why not upgrade while you're at it?
    Did they and if so, what is the difference?
    WillySTS is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Feb 2006
    Los Angeles
    65
    627
    Re: Head gasket question
    We'll find out in the long run...or I will, since I bought my car, most of you seemed to have leased.
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    2000+ FWD Northstars have dramatically fewer instances of HG failure.
    2004+ RWD Northstars are 80% new, and the SC versions are even stronger, so I suspect its a total non-issue.
  5. #4
    Eldo1953's Avatar
    Eldo1953 is offline Cadillac Owners Enthusiast
    Automobile(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
    Feb 2003
    Winnipeg, MB
    756
    I wouldn't worry about it. We have only ever seen 1 failure on this site in the newer (2004+) RWD Caddys, and the engine only had a few thousand miles on it so there was clearly a manufacturing defect.
  6. #5
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Enthusiast
    Automobile(s): 10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
    Mar 2006
    NC
    574
    davidstan had one
  7. #6
    Jan 2008
    161
    was it on an STS-V?
  8. #7
    Nov 2005
    Georgia
    403
    Quote Originally Posted by BMBSALES View Post
    davidstan had one
    yes my first sts v blew the head gasket after i think 1200 miles or so. Dealer gave me new car so no problem. I'm pretty convinced it was rare.
  • You may not post replies
