Bluetooth Pairing issues ? (I did run a search) - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 48
Cadillac STS-V Series Forum Discussion, Bluetooth Pairing issues ? (I did run a search) in Cadillac V-Series Forums; Thanks Master Florian...
  1. #31
    CIWS's Avatar
    CIWS is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
    Dec 2005
    D/FW Tejas
    25,514
    Re: Bluetooth Pairing issues ? (I did run a search)
  2. #32
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Glad to have helped, I'd be happier if he listed the new software versions in the story.
  3. #33
    Florian's Avatar
    Florian is offline crushing Vs with my Wurm
    Automobile(s): 2013 GT500 - 700+ HP
    Aug 2003
    location, location
    12,266
    Quote Originally Posted by CIWS View Post
    its certainly a pleasure to have you here....
    F
  5. #34
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Quote Originally Posted by ewill3rd View Post
    I can go back and look over the invoice some more, but I retyped that from the field on the invoice where he placed the notes.
  6. #35
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    This is what it should have, not sure if you can get someone to hook up a Tech 2 or not...
    Select: F1 Navigation radio. Verify that the software versions are:
    - Navigation system software version = 0FC1
    - Audio system software version = 010C
  7. #36
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    I don't see those numbers anywhere on the invoice, however the performance shop where I had the CTSV tuned and will get the STSV dyno'd has a tech II and I can probably get them to check it. Thanks for the version numbers
  8. #37
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Got this checked this evening while I had the car dyno'd.
    Nav - 0FC1
    Audio - 010C
    Soft Part # 15876179
    Sounds like they did it correctly.
    The car did get "stuck" however in "Accessory Active" This came up on the display along with the message to place the car in Park. The car was in park and would not come out of this mode. I could start the car but there was no MPH readings when driven. You could shift the car from park,reverse,nuetral, and drive but it didn't know that it was (display had no gear readout), also when it was in reverse the reverse lights did not come on. When you went to shut the car off the engine would stop but it stayed in Accessory Active and continued to say to put the car in park, despite it already being there and the Nav screen would stay on (displaying the Cadillac logo and STS). After trying several different things I finally pulled the battery terminals and let it sit for about 10 minutes. After hooking them back up the car returned to normal functioning.
    Seen that before ewill ?
  9. #38
    thefred's Avatar
    thefred is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS-V
    Sep 2004
    Atlanta, GA
    817
    So what were the dyno numbers?
  10. #39
    Silver Dollar's Avatar
    Silver Dollar is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Apr 2006
    Taxus
    4,042
    The only pairing you need to be worried is the one for the Saturday night square dance down at the community center gramps.
  11. #40
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Sounds like you had some sort of logic lock there.
    I haven't seen that, but it sounds like a communication issue maybe.
    Let me know if you see it again, I can do some research.
  12. #41
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Quote Originally Posted by thefred View Post
    366.5 rwhp on run # 3 - It was raining pretty heavy so the air was really moist, plus as you'll see the stock tune has the car running VERY rich.
    [YOUTUBE]yNiV_AmDqqU[/YOUTUBE]
    Quote Originally Posted by Silver Dollar View Post
    All I know is my Powerchair is faster than yours
    Will do ewill. If anything I just wanted to pass on what happened and how it was solved to you.
  13. #42
    thefred's Avatar
    Sep 2004
    Atlanta, GA
    817
    Excellent..now we know where we started....lets see what you can do with it!!
  14. #43
    Apr 2006
    Taxus
    4,042
    Blue hair pairing issues?
  15. #44
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Just a follow up post. I went back to Verizon and showed them the phone would not pair with the car, they tried it as well with two different phones of the same model and had no luck. So they allowed me to swap out phones for no additional charge. I ended up with an LG enV VX 9900 and it works just fine with the car.
    Apparently Mercedes has the same type of issues with very few phones working well with their bluetooth, so a friend provided me a list they gave him of phones they have tested and know work. They were listed by carrier, make, model, and software version. Mostly Motorola phones with a few from Nokia, LG, Blackberries, and the Apple iPhone. No Samsungs were on the list. So I tried an LG and it works.
  16. #45
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Feb 2007
    Naperville, IL
    393
    CIWS,
    I would love a copy of that list. My wife's MB won't mate with any of the phones she has tried either. Works with mine, but I have a Motorola. She has to use a Verizon for company business, and would love to know which ones might work.
    Thanks! Bob
  17. Remove Advertisements
