Engine control module - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Cadillac STS-V Series Forum Discussion, Engine control module in Cadillac V-Series Forums; Originally Posted by Davidstan http://www.vectormotorsports.com/ Good questions. Try the above link and give them a call. They are pretty good ...
  1. #16
    Florian's Avatar
    Florian is offline crushing Vs with my Wurm
    Automobile(s): 2013 GT500 - 700+ HP
    Aug 2003
    location, location
    12,266
    Re: Engine control module
    Quote Originally Posted by Davidstan View Post
    Good questions. Try the above link and give them a call. They are pretty good at explaining the process. Their cost is 499.00 for the flash and i asked about a group discount but they said it was having trouble recouping the R/D
    cost as it is.
    R&D costs?, please. My best friend is a PCM tuner for a living...takes him about a day to figure things out. The majority of the time its fuel trim/tables that need adjustment. The other goodies are easily attainable (smoother, faster shift points, speed limiter removal, higher rev limit, etc.) So Vector is pulling your pud when they hem and haw about a GB. I bet they could get 10 jobs TODAY if they dropped their price to 349 or even 379. Hope theyre lurking.
    F
  2. #17
    Florian's Avatar
    Aug 2003
    location, location
    12,266
    BTW, the CST-V ECU was in front of the driver side tire. You had to get under the car and open up a little 'box' that housed the ECU. There was a 10mm bolt that kept it closed, but it wasnt a truly 'sealed' box, so all sorts of road debris and salt got in there. Once the bolt was removed you just slid the ECU out and detached the 2 harnesses that were there (red and blue).
    I havent found the ECU on the STS-V yet, Ill look it up on the GM-SI to see how they recommend removing it.
    F
  3. #18
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    STS-V ECM is located underneath the air cleaner housing but don't access it from above. Do it from below, it is a lot easier.
    CTS-V is in a similar location, also accessed from underneath.
    If the dealer reprograms the ECM whatever "tune" you have in it will be erased.
    There is no indicator to us that it has been reflashed with a tune, if you want to keep it make sure your dealer knows not to reprogram it without your foreknowledge.
    Take the stuff off from underneath the car, I am not sure taking the wheelhouse trim out will get you there.
    I have one here in the shop, I'll look later and tell you if any of my advice needs to be "modified"
  5. #19
    stephenstay is offline Cadillac Owners Member
    Automobile(s): 2015i Cadillac Escalade, 2007 STS-V
    Sep 2007
    Victoria
    51
    Ah yes, from underneath the car. Well, at least I now know how to remove the air filter assembly
  6. #20
    Sep 2007
    Victoria
    51
    Well, I fought my way into the ecm. You can get to it from above if you take the air cleaner out and you'll find it hiding beneath the horns. One nut removes the horn bracket and you're there. I'm sure it is easier to get to it from below but I already had the filter assembly out ...
  7. Remove Advertisements
