Rear differential leak again - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 57 of 57
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Rear differential leak again in Past Cadillac Vehicle Discussion; I think you are probably alright if the car has gone that log without trouble, but then again, if you ...
  1. #46
    rb92gt's Avatar
    rb92gt is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Lux, 2011 Escalade EXT Prem
    Aug 2006
    Summerland Key, FL
    38
    283
    Re: Rear differential leak again
    I think you are probably alright if the car has gone that log without trouble, but then again, if you did not own it, you can't be sure if it has had any problems or not. I just got my car back a few days ago from the Cadi dealer, replaced the entire rear diff this time. I would estimate the cost for an entire rear diff is around $3K. The carrier (housing) itself is $1K, not including any labor or additional parts. I think the STS is an awesome car, you can have problems with any car... yes even Mercedes, BMW, Lexus etc. I would highly recommend though that you find a cadillac certified car, mine was when I bought it last year and my warranty is good until 2012 or 100K miles, whichever comes first... that warranty is even better than what I would have received if I would have bought a brand new 2006 STS off the lot the day I bought the car.
  2. #47
    aliskerov is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS
    Sep 2011
    27
    125
    Alright, well, I looked under my car yesterday and realized that there is an oil streak down the side of my differential and oil periodically drips down from it. Seems like I'm in the same boat. I'm hoping I can hold out until warmer days to do this repair. A few questions though: has anyone here tried tightening the bolts up a bit? That's the first thing I was going to try. Secondly, from the countless posts on this topic, it seems that the gasket between the differential casing and the cap is the weakest link. It also seems like the replacements supplied by the dealer are no good. Does anyone here know of a good aftermarket gasket or if there is any reason NOT to make your own with the red RTV stuff?
  3. #48
    RobertTarabella is offline Cadillac Owners Member
    Automobile(s): Escalade, STS, Allante
    Dec 2014
    I have the common leak in the rear differential. Does anybody know the typical vehicle miles when this appears?
  5. #49
    stevenriz is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    482
    my 05 had a leak as well but not until about 85k miles. Don't remember the cost. For not replacing the entire diff, what is the cost to repair the seals for you guys?
  6. #50
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,213
    Holy dead thread Batman!
    Don't mess with Binky Bear!
  7. #51
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    Quote Originally Posted by dkozloski View Post
    This thread just likes to be reborn every couple years.
  8. #52
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    29
    202
    My pinion seal started leaking at 95k. Dealer quoted me $900 to replace. I got the seal off of ebay for around $65 part number for mine was 19179933 and did it myself. It was a pain but doable..
  9. #53
    kirk55 is offline Cadillac Owners Member
    Automobile(s): 2008 sts
    Dec 2014
    62
    1
    My diff was showing a small drip so I went under to take a peek. it looked like the gasket was leaking from the second bolt from the bottom on the drivers side flange. I cleaned it up to see if I could see any wash in the road dust no drip for four days then drop on floor today. when I went under today I noticed a crack in the cover where the differential flange extends to frame. I cleaned the area around the crack and used some differential rtv sealer to see if I can seal it up. I hate to think of pulling axels and diff to repair this obvious faulty part. out of warranty.
  10. #54
    Jramsey420 is offline Cadillac Owners Member
    Automobile(s): Cts
    Oct 2015
    37
    5
    My 05 cts is leaking brake fluid from the differential and I believe it is from traction control anyone else have this problem or had this problem
  11. #55
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,496
    The thread is reborn again!
    Quote Originally Posted by Jramsey420 View Post
    This I highly doubt. If your diff is filled with brake fluid you've got bigger issues.
    What is wrong with traction control? What codes do you see?
    KRSTS likes this.
  12. #56
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You would be better served posting on the CTS forum. Your favorite search tool will give you links to threads on the CTS brakes, which aren't the same.
  13. #57
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,213
    FWIW, STS differentials like to push a little oil out through the vent in the top.
  14. Remove Advertisements
