Rear differential leak again - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 57
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Rear differential leak again in Past Cadillac Vehicle Discussion; I just spoke with a Cadillac Service Rep this afternoon regarding the differential leak. He said that it's the pinion ...
  1. #31
    coati's Avatar
    coati is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2007
    The SF Bay Area
    185
    Re: Rear differential leak again
    He said that it's the pinion seal & that it's a common problem w/CTS, SRX & STS models.
    Will have mine checked out when I bring it in next time.
  2. #32
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    This rear is shared among a variety of GM vehicles, and they all report problems.
    Ed
  3. #33
    Mar 2007
    San Antonio, Tx
    4,769
    Quote Originally Posted by rb92gt View Post
    Hey,
    Have been less than impressed with this issue, car drives great, but sad that two weeks after having seals replaced in diff, it is leaking again. Cadillac sits next to my 1992 Mustang GT in my garage and only the floor under the Cadillac has oil stains. The Ford with 100,000 miles has been bone dry and the $56,000 Cadi leaks oil. Pitiful.
    What do you want for $50 or $60k? You should have bought a real Cadillac, a Fleecewood Brougham.
    Sorry about the rear end problems. I just bought a CTS, and I need to climb underneath it to look for such problems.
    Ed
  5. #34
    CTS11723 is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Feb 2005
    43
    The entire rear differential had to be replaced in my 2005 STS a few weeks ago. Ever since, my car whines during acceleration and deceleration. Is this normal?
  6. #35
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Just got my STS back from the Cadillac dealership for repairs.
    They replaced the pinion seal & differential oil.
    Hope it does the trick.
    We'll see.
  7. #36
    ascariSTS is offline Cadillac Owners Fanatic
    Automobile(s): '06 STS V8 RWD - Black Raven/Cashmere - no ACC
    Jul 2005
    316
    Is this a big issue ? ... I mean can I just leave it ?
    I find some oil from time to time under my car... but it's a little...
    What problems I can get if I leave it?... I don't want those non-educated mechanics at the dealer play with it...
  8. #37
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    There is the possibility of differential gear "whine" if the fluid level gets low.
    That was the case for my STS according to the service rep.
    I would get it checked out & repaired.
  9. #38
    garyt is offline Cadillac Owners Member
    Oct 2006
    7
    2006 STS V6
    I had the differential leaks repaired two times, and then they replaced the differential. It leaked once more and they replaced a “gasket.” I’ve got 15,000 miles and it hasn’t leaked in the past 8,000 miles.
  10. #39
    Jul 2005
    316
    So is it the gasket, not the pinion seal ?
  11. #40
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    The rear ends in STS and CTS automobiles are very similar in design but are not identical. http://www.getrag.de/307.1?_search_=..._=0&_offset_=0
    This is an example of superior German products.
  12. #41
    Davidstan's Avatar
    Davidstan is offline Cadillac Owners Fanatic
    Nov 2005
    Georgia
    403
    Mine started leaking with 1000 miles and got the dealer to replace pinion seals and blowhole seal. My ctsv leaked also but not near as much. Its irritateing but thats about all. Had a leak spot on my garage floor already anyway.
  13. #42
    rb92gt's Avatar
    rb92gt is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Lux, 2011 Escalade EXT Prem
    Aug 2006
    Summerland Key, FL
    38
    283
    For the past 4 months, no leaks, thought was all fixed after dealer put in "vent tube" in rear diff. Pulled car out yesterday, and again, oil on floor. Will eventually go back to dealer for 4th time. Guess I get to drive a loaner again... which one shall I choose this time??? Really a sad situation... if I didn't love car so much, would be screaming lemon.
  14. #43
    Mar 2007
    San Antonio, Tx
    4,769
    GM service mgr tells me that they have a GM additive that will resolve the leaking problem?????
    Try a large Caddy dealer for verification of this info. My guy is pretty sharp and has been there for 20 yrs.
  15. #44
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,374
    I dont know about an additive, but I know for the XLR GM has been swapping the fluid for a synthetic. That, however, is for resolving gear noise, not leaks.
  16. #45
    DTS_BOI's Avatar
    DTS_BOI is offline Cadillac Owners Fanatic
    Sep 2007
    159
    I was going to purchase a used 2005 STS with like 40K miles.. Should I avoid purchasing one? How much money are we talking for a repair if the car is out of warranty? By 40 or 50 thousand miles, do you suspect that the problem should have been fixed?
  17. Remove Advertisements
