Automatic Level Control
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Automatic Level Control in Past Cadillac Vehicle Discussion; PLEASE!!! SOMEONE HELP!!!! This is driving me batty! I cannot for the life of me to get my ALC compressor ...
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 08 STS V8 AWD, 1SG, Platinum Edition
    Jan 2003
    Fresno, CA
    682
    PLEASE!!! SOMEONE HELP!!!! This is driving me batty! I cannot for the life of me to get my ALC compressor to come on. Does ANYONE know if theirs comes on? It is supposed to come on 30 seconds after the vehicle is started for the air replenishment cycle and then as needed when weight is added to the vehicle but it does not come on, or I have not heard it. It does not come after I start the car or when weight is added. Someone had mentioned that the car had an automatic system that leveled itself without a compressor but instead with a system that is integral in the shock but that is not the case. I got an 06 STS factory manual and it does say that my car has the compressor system and should work like I mentioned but does not. I even found where the compressor is located underneath the car with the air lines going to the shocks so I know the car has it. The last time I took it in for service, I had the dealership check out the system and they said it worked fine, which I suspect is incorrect. I briefly spoke to the tech and he said he checked it out with the TECH II and it worked fine but maybe it doesn't work properly normally. Again, has anyone ever heard their compressor come on?
    Thanks,
    Max
    jhschlak is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6 DI
    Aug 2006
    127
    Re: Automatic Level Control
    I hear mine come on every time after I close the trunk. Whether I put anything in there or not.
    -Jeff
    Skibanker is offline Cadillac Owners Fanatic
    Automobile(s): 2015 XTS Luxury
    Jan 2006
    Florida
    153
    Quote Originally Posted by Maximln View Post
    Thanks,
    Max
    Max, try opening the trunk and sitting on the trunk frame. If you sit there for a minute or two watch over a fender or some fixed part of the car and you'll see that the car is indeed rising.
    Jan 2003
    Fresno, CA
    682
    Believe me, I've done that and NOTHING happens. I don't hear anything, see anything or feel my feet lifting off the ground. If you guys do indeed hear your compressor, there must be something wrong with mine then.
    Max
    Jan 2006
    Florida
    153
    Max
    Try again, Max. The movement is VERY subtle. You won't feel yourself rising or your feet moving. The only way I can tell is by looking past the fender to some fixed mark on the garage floor or wall for a minute or two. The car will SLOWLY rise.
    Jan 2003
    Fresno, CA
    682
    But do you hear your compressor come on?
    Thanks,
    Max
  9. Remove Advertisements
