Redline
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Redline in Past Cadillac Vehicle Discussion; I was showing off the STS to some friends today, and was using the manual shift mode on my v6. ...
    jhschlak is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6 DI
    Aug 2006
    125
    Redline
    I was showing off the STS to some friends today, and was using the manual shift mode on my v6. At one point it got up into the red area between 6 and 7 on the tachometer for a second or two. Would a one time venture into this area cause any problems? I think I am a bit paranoid, but just wondering.
    Thanks,
    Jeff
    Devil_concours is offline Cadillac Owners Connoisseur
    Jan 2003
    Alexandria, VA
    34
    3,684
    Re: Redline
    Quote Originally Posted by jhschlak View Post
    Thanks,
    Jeff
    not an issue.
    I used to hit 10k rpm on rx7 on regular basis.
    997tt's Avatar
    997tt is offline Cadillac Owners Member
    Automobile(s): 05 STS V8
    Sep 2006
    32
    82
    Re: Redline
    Not an issue.. especially only one time. Don't sweat it one bit. Once my sister drove my acura tl type-s on second gear at 100-110km/h, thats at 6500RPM redline for half an hour! Nothing happened... as long as it had enough oil in the engine everything should be a-ok. Engines can usually take a little bit more but are protected to even longer life of the engine, and also that it would be useless to rev any higher because you already hit your peak hp at about 800-1000rpm less then the redline.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,393
    Re: Redline
    Unless your engine is below 3 K miles ,you can do it with no problem .You know some owners having WOT which means getting red line . As for me ,I don't like it for fear of hurting the engine even though I know we have a quite smart car and it's not recommended babying it
    somebody09 is offline Cadillac Owners Member
    Jan 2005
    19
    Re: Redline
    Why are you imbiciles comparing GM's engine to Mazda's and Honda's? Do they share the same internals? Do they share the same valve train? Do they share the same transmission? If they do, please let me know 'cause that means I'm out of the loop!
    Jan 2003
    Alexandria, VA
    34
    3,684
    Re: Redline
    Quote Originally Posted by somebody09 View Post
    wow someone is cranky today.
    He was hitting the rev limiter meaning it was within the safe parameter. 3.6l v6 in his car uses forged crankshaft and connecting rods.
  9. Remove Advertisements
