AWD STS4 transmission software fix - Page 5
Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 61 to 75 of 109
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, AWD STS4 transmission software fix in Past Cadillac Vehicle Discussion; Has anyone noticed any change in gas mileage after doing the transmission up date on a STS4-V8??..........either better or worse??...
  1. #61
    throhrer is offline Cadillac Owners Member
    Automobile(s): 2005 STS-4
    Sep 2009
    73
    10
    Re: AWD STS4 transmission software fix
  2. #62
    bierman.d is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 V8
    Apr 2009
    Iowa
    154
    Should be the same.
    Mine is.
  3. #63
    DCnative is offline Cadillac Owners Member
    Automobile(s): 08 CTS 3.6L AWD & 16 SRX AWD
    Nov 2007
    Washiington DC Area
    15
    OK looks like I am joining the club about the fourth gear chuggle. Traded-in my 2001 STS V8 for a 2009 V6 DI AWD STS this past June. Enjoying the car with the Bluetooth/NAV/AWD…but the transmission is beginning to worry me. In September, I had the dealer service floor manager test drive and recommended to flash the transmission which improved the hard downshifting. In the past few months my concern now is when the car gets up to 60 MPH and shifts into fourth gear @1700RPM's comes the chuggle. If anyone else is experiencing this issue with the V6 DI AWD, would welcome comments and recommendations.
  5. #64
    is not null is offline Cadillac Owners Member
    Automobile(s): 2009 STS, 2010 SRX-T
    Oct 2009
    47
    81
    Quote Originally Posted by DCnative View Post
    Same here! 2009 V6 DI AWD. I notice it most when going up hills doing around 60 MPH. I'll be taking mine in for minor cosmetic repairs and I was going to mention it to them then. When that happens, I'll post what happens.
  6. #65
    turnne is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac STS
    Oct 2007
    Indianapolis Indiana
    53
    1,209
    I have an 05 AWD V8
    they reflashed the trans...worked better for a little while( 2500 miles)
    Then starting the chugging again. The just replaced the torque converter...replaced the trans fluid, filter and seals
    All seems good now
    Warren
  7. #66
    themightymezzo is offline Cadillac Owners Member
    Jul 2008
    75
    Quote Originally Posted by turnne View Post
    All seems good now
    Warren
    Should be...."All seems good FOR now". I have had them replace these items several times, went several weeks, months only to have the problem always resurface.
    I just see how long I can push it out before taking it back to em since it's such a hassle.
  8. #67
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,241
    I have an '06 AWD V8 STS and I've never done anything but drive it and it performs flawlessly. No chuggles, no hard shifts up or down, no milage problems. I guess ignorance is bliss.
    MikesCaddy06 likes this.
  9. #68
    Jul 2008
    75
    Yeah it's funny some people never have had the problem and others have. And there seems to be no pattern as to which ones have it and which don't.
  10. #69
    CB STS-4 is offline Cadillac Owners Member
    Automobile(s): 2006 STS, 2005 Escalade
    Feb 2010
    1
    QuestionRe: AWD STS4 transmission software fix
    Found the information on this forum and got mine fixed about 1500 miles ago. I hope the fix lasts but I am coming up on warranty expiration in about a month. If this fix doesn't work, the TC replacement is the next step.
    I am seriously considering getting the GMPP extended warranty, but it is seems very expensive. The STS-4 is loaded with features that seem costly to repair so maybe it will be worth the peace of mind for the $3000-4000 cost.
  11. #70
    M.A.C's Avatar
    M.A.C is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS-V8
    May 2004
    New Jersey
    349
    Quote Originally Posted by EChas3 View Post
    Did they do anything else? I had an issue they thought was the drive-by-wire gas pedal control. It turned out to be a throttle-body wiring connector.
    OK. The TCM programming helped. The problem continued to get worse. Software couldn't revert to OEM unless it was never saved. One or more of the inputs to the TCM could cause it to misbehave.
    My '05 STS (RWD) shifts hard from 1st to 2nd because of delayed shifting out of 1st. So I'll let up off the gas to decrease rpms so I don't get a hard jerk when it shifts. Otherwise, I'll accelerate slowly to avoid the higher rpms until it shifts to 2nd. Sometimes the hard 1-2 shift goes away which is a real treat.
    I called OnStar about my monthly diagnostic report and was told that I have a code related to the Throttle Body and/or air intake sensor. I was told the issue causes inaccurate air intake readings which in turn could cause harsh shifting. I replaced the Throttle Body but the problem still persists. I have to buy a code reader to find out why my check engine light is on which I hope will pin down exactly what is going on as it relates to this air intake sensor or whatever it is. I checked the Throttle Body harness and didn't see anything wrong with it.
  12. #71
    Oct 2007
    53
    1,209
    Quote Originally Posted by throhrer View Post
    Mine seems to be a bit bitter...I also noticed that the car feels faster off the line
    Warren
  13. #72
    howiex is offline Cadillac Owners Member
    Automobile(s): 2008 STS-AWD
    Feb 2010
    9
    What year STS are you guys talking about? I have a 2008, should I be worried.
  14. #73
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Well my 05 was just done.
    I like that it doesnt slam into gear or seem indecisive when attempting to pull a hill under moderate throttle, however I used to engine brake the car to a stop when exiting the highway, the car just doent let itself kick down into a lower gear as fast as it used to. It almost makes me wish that I hadn't had the update done.
  15. #74
    bbshriver's Avatar
    bbshriver is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS V8
    Mar 2008
    Allentown, PA
    31
    574
    I had the update done on my car (RWD only), and am very happy with it!
  16. #75
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,983
    For those with 2009s; the SW fix has been out for a long time. I don't think it would make sense that they would be putting out new cars without the update, unless the the update is only needed for a small percentage of the cars that have something physically wrong. But why wouldn't they have addressed that?
    But let us know what the dealers say.
  17. Remove Advertisements
