Results 1 to 12 of 12
Thread: Radar Dectector
    Aurora5000's Avatar
    Aurora5000 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Blackberry,2004 CTS 3.6 Loaded, 2016 SRX LOADED
    Oct 2003
    Tornado Alley Oklahoma City
    482
    Radar Dectector
    Where is the best place to get 12V that shuts off when exiting the car?
    Thanks
    Aurora5000's Avatar
    Oct 2003
    482
    Re: Radar Dectector
    Anyone?
    Benjamin Simon's Avatar
    Benjamin Simon is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS V8 1SG with ACC, 99 STS (Sold), 06 CL500 (Wifes)
    Jun 2005
    Middle GA
    34
    960
    Re: Radar Dectector
    I think all of cig lighters turn off after a set amount of time. Is that the answer you needed?
  5. #4
    Cajonkev's Avatar
    Cajonkev is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-1SG-ACC/HUD-Volant CAI-Corsa Exh-Mesh Grill-ClearBra
    Jun 2005
    Vista, CA
    51
    516
    Re: Radar Dectector
    Run a couple of searches on "radar detectors".
    As I recall there were a couple of folks that pinned out and voltage tested the wiring to the mirror and the genreal area in search of switched 12v.
    If the answer is not posted. IM those who were looking. They may have found it and not posted it to the boards.
    Good luck and please post it if you find a switched hot wire to use...
  6. #5
    Aurora5000's Avatar
    Oct 2003
    482
    Re: Radar Dectector
    The 12V plug in the center console does not turn off. I will run a search again for switched 12V.
    Thanks.
  7. #6
    Aurora5000's Avatar
    Oct 2003
    482
    Re: Radar Dectector
    After trying the fuse boxes under the back seat, I did not find any that were switched. Most were hot all the time or 5 volts. These 12 v fuses must be upstream of the switching. Other forums have suggested to get switched 12 volts, go to the reading lite or mirror area and look there.
    Thanks
  8. #7
    Aurora5000's Avatar
    Oct 2003
    482
    Re: Radar Dectector
    I went to the reading lite console and pulled down with a thin blade screwdriver. Has 6 metal clips that hold it on. I used the switched 12v that supply power to the 2 reading lites. There is a 3 wire plug that powers both lites. The hot wire is a green wire with a white stripe on it. The ground wire is black. Tapped into those two. Power is turned off after 10 minutes each time. Easy to do. Thanks to all for your help.
  9. #8
    Cajonkev's Avatar
    Jun 2005
    Vista, CA
    51
    516
    Re: Radar Dectector
    Thanks for letting us know the outcome!
  10. #9
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Enthusiast
    Automobile(s): 10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
    Mar 2006
    NC
    574
    Re: Radar Dectector
    Quote Originally Posted by Aurora5000 View Post
    for next time...there is a very simple jumper in the fuse box...cost $3...no 10 min wait. if anyone is interested...
  11. #10
    Aurora5000's Avatar
    Oct 2003
    482
    Re: Radar Dectector
    I would like to hear your solution...
  12. #11
    thu's Avatar
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    Re: Radar Dectector
    I grabbed my 12v from the passenger side visor lights. They auto switch off if I forget to turn off the detector. Since the visor lights wires run very close to where I need the power, it was simple.
  13. #12
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: Radar Dectector
    ILL SNAP A PIC OF THE JUMPER. I'VE DONE IT TO EVERY GM VEHICLE I OWN AND HAVE HAD NO PROBLEMS.
  • You may not post replies
