Farting or groaning noise from climate control system
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Farting or groaning noise from climate control system in Past Cadillac Vehicle Discussion; Hello0o0o, The forum is really dead... few threads, few posts... That means one thing... STS has very few problems anyways, ...
    ascariSTS is offline Cadillac Owners Fanatic
    Automobile(s): '06 STS V8 RWD - Black Raven/Cashmere - no ACC
    Jul 2005
    316
    Hello0o0o,
    anyways, that farting noise coming from the AC (when you switch air circulation)... It's drivin me nutzZzzzZzZzz.....
    Any solution to that?... is there any TSB ?
    Cajonkev's Avatar
    Cajonkev is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-1SG-ACC/HUD-Volant CAI-Corsa Exh-Mesh Grill-ClearBra
    Jun 2005
    Vista, CA
    51
    516
    Re: That fa*ting noise again
    There isn't a TSB or advisory that I'm aware of yet but when asked my Service Manager new immedietely of the issue and had a fix action for it. Although I have the issue I didn't have it done (for other reasons) but he has been straight up with me on everything else to date.
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    What did the repair involve?
    Cajonkev's Avatar
    Jun 2005
    Vista, CA
    51
    516
    We were dealing with a seperate issue that I didn't want to get off track of so I didn't dig any further at the time. I'll post it when I talk to him next.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    Is it vacuum related?
    Jul 2005
    316
    05STSWOW's Avatar
    05STSWOW is offline Cadillac Owners Member
    Automobile(s): 2008 STS 1-SG, traded in 2005 STS4 1-SG
    Mar 2005
    Atlanta
    85
    I had the same problem months ago and was able to replicate the noise for the service advisor. I called it the seat farts. It is apparently an hvac valve servo (electric or vacuum, I don't know). I think it was a lubrication issue. Capital Cadillac Atlanta fixed it under warranty. No further problems, but it was good for a few laughs for a while...
    GA1019 is offline Cadillac Owners Member
    Apr 2005
    19
    mine does it too......i agree it is some sort of a/c mixing door operation
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I have fixed two of them, it's a clearance issue but heavy lubrication will fix it.
    If you turn on the A/C and then press the recirculate button it will do it, press it again and wait a few seconds then press it once more. You'll hear the noise. The cam that drives the recirculation door is tight and it causes a noise on the actuator arm.
    You have to remove the glove box to reach the actuator. The first one I did I removed the whole blower assembly to locate the noise, the next one I just lubricated. It's easy once you get the glove box out. If I do another I'll take a picture.
    You just have to lubricate the pin off the actuator where it goes into the cam and the noise will stop after a few cycles.
    Joe Gros is offline Cadillac Owners Member
    Mar 2006
    4
    Back in March I started a thread called "Passing Gas" which sounds like the same sound described in this thread. I finally diagnosed the problem for the dealer and he changed the recirculating actuator, under warranty, and it seems like the problem is fixed.
    Cajonkev's Avatar
    Jun 2005
    Vista, CA
    51
    516
    My servicing dealer also takes the "lubrication" route and has done several already.
    I had them do mine 4-5 months ago and it was still fine when I turned it back a couple of weeks ago.
    Jul 2005
    316
    Quote Originally Posted by ewill3rd
    Thanks a lot for the help...
    I'll drop my car at the dealer's this saturday.. i'll tell you about it...
    Jul 2005
    316
    ewill3rd and Cajonkev
    Thanks a lot for the help... I took my car to the dealer and told them whatever you told me... It works... .the noise disappeared
  16. #14
    Cajonkev's Avatar
    Jun 2005
    Vista, CA
    51
    516
    Glad it worked, and I hope it lasts!!!!
  17. #15
    justgreat is offline Cadillac Owners Fanatic
    Jan 2003
    309
    this board is quite lucky to have a caddy tech on the watch, so to speak...thanks, ewill3rd. it's good to have "an inside view" of our caddys.
    jackg
    06 sts6 on order
  18. Remove Advertisements
