Farting or groaning noise from climate control system - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Farting or groaning noise from climate control system in Past Cadillac Vehicle Discussion; Remove the glove box and lube the acuators...
  1. #31
    DarkMingBlueSTS's Avatar
    DarkMingBlueSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 6 CYL
    May 2012
    497
  2. #32
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Re: Farting or groaning noise from climate control system
    In the upper right hand corner there is a Search box, put in "Farting Noise"
    and click on appropiate links. I'm sorry I cannot find my posts on this either.
    Good Luck, I have done this twice, one on each car.
    It worked GREAT, and Kept on working...
    The Jist of this is: what DarkMingBlueSTS, says above,
    Remove the glove box, and lube the actuator arms.
    Do IT once , and it's done.
    Have fun.
  3. #33
    thekid911 is offline Cadillac Owners Member
    Automobile(s): 06 sts
    Jun 2013
    1
    Can someone contact me about how to fix this problem. markk439@gmail.com
  5. #34
    May 2012
    497
    Quote Originally Posted by thekid911
    Lube the actuators and the problem will be gone
  6. #35
    06 STS Rob's Avatar
    06 STS Rob is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS V, had 06 V6 STS
    Jul 2010
    Lake Elsinore,CA
    40
    427
    Quote Originally Posted by thekid911 View Post
    Just leave it and blame it on your wife! It's more intertaining that way....
  7. #36
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    They have also redesigned the levers.
    Lube is an easy short term fix. Replacing parts might be a bit harder but not expensive to have done.
  8. #37
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    I lubed mine with silicon grease a couple of years ago and it's been quiet ever since.
    Don't mess with Binky Bear!
  9. #38
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Good to hear it didn't need a repeat treatment.
  10. #39
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    Feb 2013
    NY
    247
    Where are the actuators? I took my glove compartment out yesterday and couldn't see where I'm supposed to lube. The noise is coming from a duct sorta off to the left a little.
  11. #40
    May 2012
    497
    Quote Originally Posted by Cadzilla8
    Turn on the ac, go through different modes, look back there for moving parts, and lube those moving parts
  12. #41
    nate6966 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade Lux AWD; 2005 STS N*AWD 1SG
    Mar 2016
    Spokane, WA
    169
    Old thread, I know. But, the 2005 STS 1SG I just bought a couple months ago has apparently been "fartin" around for over 10 years as the previous owner never got this fixed.
    Thanks to these threads and AllData, I spent $15 on the repair kit (a new actuator arm, rotation pin, and grease) and did the repair myself.
    Super quiet recirculation/fresh air cycling now!
    Just for future forum members... this repair is best done according to the TSB, replacing the actuator arm and rotational pin. Simply greasing it up is a temporary fix.
    And it's super easy if you just go ahead and unbolt then lower the air intake box. It was only held in by three 10mm bolts and that makes the actuator completely accessible.
    Sent from my SM-G900V using Tapatalk
  13. Remove Advertisements
