Fuel - Regular /Mid-Grade or Premium?
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Cadillac STS Forum - 2005 through 2012 Discussion, Fuel - Regular /Mid-Grade or Premium? in Past Cadillac Vehicle Discussion; Dealer sez regular unleaded is fine for my 2005 STS... Anybody disagree or having good luck with 87 octane?...
    Space is offline Cadillac Owners Member
    Automobile(s): 2005 STS V-6 Luxury Performance
    Jan 2006
    Chicago
    48
    27
    STS2002's Avatar
    STS2002 is offline Cadillac Owners Fanatic
    Automobile(s): None
    Sep 2004
    198
    Re: Fuel - Regular /Mid-Grade or Premium?
    Quote Originally Posted by Space
    I have the V8 and it is recommened to use premium, however, i have used regualr and have not noticed a difference.
    Phil
    don_mccarter is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Nov 2004
    Oakville, Missouri
    208
    My V8 STS runs much smoother on premium.
    Premium is only 20 cents more than regular in my area.
    ascariSTS is offline Cadillac Owners Fanatic
    Automobile(s): '06 STS V8 RWD - Black Raven/Cashmere - no ACC
    Jul 2005
    316
    you can see it in the manual...
    V6 can have regular fuel... using premium on V6 is only a waste of money
    V8 must have premium only (high octane) ... don't try to use regular fuel... it will harm your engine
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Whatever is says in the owner's manual.
    Using anything else is a waste of money and not really very good for your engine.
    Octane is a rating of "knock supression" used to identify the fuel you need based on the compression ratio of your engine.
    If you have a high compression engine you need a higher octane.
    Using high octane fuel in a low compression energy is almost harmful to the car.
    Just check the owner's manual and put in the octane level it calls for based on what engine is in the car.
    BarryNS is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS V8 RWD 1SG+Perf Coll. + Perf Handlin pkg
    Mar 2005
    phoenix
    209
    This information is from the 2005 STS manual. You can see that using anthing 87 Octane or up is acceptable and won't harm your engine. Best performance is with 91 Octane. With the price of gas today it is understandable that many might want to use 87 most of the time.
    If your vehicle has the 4.6L V8 engine, use premium
    unleaded gasoline with a posted octane of 91 or higher
    for best performance. You may also use middle
    grade or regular unleaded gasoline rated at 87 octane
    or higher, but your vehicle’s acceleration may be slightly
    reduced. If the octane is less than 87, you may get a
    heavy knocking noise when you drive. If this occurs, use
    a gasoline rated at 87 octane or higher as soon as
    possible. Otherwise, you might damage your engine.
    Nov 2004
    Oakville, Missouri
    208
    Quote Originally Posted by BarryNS
    I am sorry, but I for one don't understand paying 50+k for a car with
    a V8 engine and not spending 10 or 20 cents per gallon for better fuel.
    I have found that using premium fuel increases my MPG which makes
    the real cost difference even less.
    Cajonkev's Avatar
    Cajonkev is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-1SG-ACC/HUD-Volant CAI-Corsa Exh-Mesh Grill-ClearBra
    Jun 2005
    Vista, CA
    51
    516
    The local CBS News Radio station in LA did a walk-up poll (they approached people at the pump) and asked those buying premium why.
    The large majority was exactly what you just said. "If I can afford the car, I can afford the right gas to put in it. Why lower performance after investing so much." Of course out here with MTBE fuel, we need all the "umph" we can get...
    Jul 2005
    316
    100% right
    plus, we are all want the best for our cars...
    Skibanker is offline Cadillac Owners Fanatic
    Automobile(s): 2015 XTS Luxury
    Jan 2006
    Florida
    153
    PLUS grade in the V6 gives me about 10% better mileage than Regular
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    No point. My Northstar is a pre-2000 engine, which was before it was even assumed that you could throw regular in them without a problem, and Ive not noticed a lick of difference between regular and premium, not even MPG.
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,380
    The duty of a knock sensor is to detect detonation. If timing has been retarded by the computer based on a signal from the knock sensor, it means detonation has already occured.
    Detonation is bad, mmmkay.
    GEORGEC is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Ice While SRX Performance, 2005 DeVille DHS For Sale
    Sep 2005
    FLORIDA PANHANDLE
    246
    Quote Originally Posted by ascariSTS
    Please explain why you think it will harm the engine. The computer should retard the engine so that there is no preignition, thereby eliminating potential damage.
    George
  16. #14
    Jesda's Avatar
    Sep 2003
    DETROIT
    35
    22,380
    The knock sensors have to detect detonation before they retard timing. By the time the computer responds, detonation has already occured. The idea behind knock sensors and computerized timing control is to allow you to drive your car in situations or places where high octane fuel isn't available. You aren't supposed to drive the V8 on regular all the time.
  17. #15
    psykiv is offline Cadillac Owners Fanatic
    Jan 2005
    Miami, FL
    150
    I put premium on the V6. The manual says that premium is recommended on the V6 (on the V8 its required), so that is what I will put.
    Also, I've noticed slightly better mileage with premium, so the price difference isn't much.
  18. Remove Advertisements
