OnStar Digital Upgrade - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 68 of 68
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, OnStar Digital Upgrade in Past Cadillac Vehicle Discussion; I just purchased a nice, low mile 2004 DeVille. The car has OnStar, but I've been told by a dealer ...
  1. #61
    thermactor is offline Cadillac Owners Member
    Automobile(s): 2004 DeVille
    Feb 2011
    5
    Re: OnStar Digital Upgrade
    I just purchased a nice, low mile 2004 DeVille. The car has OnStar, but I've been told by a dealer that it's "good to go" with digital, but when I called OnStar, they said it was analog and had to be upgraded.
    My question: Is there a way to find out for sure? I've heard some cars had both types (analog and digital) of equipment.
    Also, what's involved in the upgrade for a car like this? Would I get to keep my mirror? How much rooting around does the dealership have to do in my dash? I really don't like the idea of anyone messing around under there - I can just imagine panels not being put back on, clips and tabs being broken, and wires not properly bundled and positioned.
    Thanks very much!
    Wes
  2. #62
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You would probably get better advice on the SDV forum but I hope you got an IOU from the seller. If the Onstar button doesn't work, you need the upgrade.
  3. #63
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,949
    The analog/digital OnStar was installed during the 2006 model year. Earlier were analog and later are digital. You can double check by entering your VIN at the OnStar web site.
  5. #64
    caddyfat2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG w/ HUD-ACC
    Jul 2010
    TAMPA, FLORIDA
    462
    Quote Originally Posted by chazglenn3 View Post
    Thats not true, I have an 05 with digital OnStar. ( If it works it's digital, if it doesn't it's analog.) or ( The black rubber antenna is digital and the rear window mounted wire one was analog).
  6. #65
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,949
    Your 2005 was upgraded to digital if it still works. It was analog when it was delivered.
  7. #66
    Feb 2011
    5
    Thanks for the clarification on the years of analog and digital. So basically, the dealer did not know what they were talking about...
    Anyway, I will take your advice and re-post in a more fiting forum about the specifics of the upgrade.
    Thanks!
    Wes
  8. #67
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,826
    This is very easy. First, try this link...
    http://www.onstar.com/web/portal/popup?articleID=192330
    There are instructions here (and a link) where you can enter your VIN.
    I've been through one of these upgrades already and it's quite straight forward. They will replace the VCIM (Voice Communication Interface Module), or the OnStar module which is located in your trunk. They will also replace the glass mount antenna, including the RF coupler on the inside of the rear glass. There will be a few programming steps with a Tech 2 scan tool as well. There will be no need for them to take your dash apart. In your case, they will not change your mirror (although this is done with upgrades in certain GM models).
    After I had mine done, I also changed the antenna (even though it was "upgraded" during the dual-mode OnStar changeover). I put a 2005 style antenna on the roof and removed the one from the rear glass entirely. The method and parts necessary to do this depends on whether you have XM radio as well.
  9. #68
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Digital upgrades on a Seville are done by removing or accessing the electronics bay in the rear of the vehicle behind the rear seat back.
    This is done by either removing the panel in the trunk or removing the rear seat back.
    Also the antenna is replaced.
    No mirrors or any other components are affected.
  10. Remove Advertisements
