Quirks with an 08 1SG; Transmission, door unlock, very very stiff ride
Results 1 to 11 of 11
Cadillac STS Forum - 2005 through 2012 Discussion, Quirks with an 08 1SG; Transmission, door unlock, very very stiff ride in Past Cadillac Vehicle Discussion; Hi all. Drove a 2008 1SG today and I liked it. just over 35k miles and have some questions. 1. ...
    stevenriz is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    483
    1. My 2005 has a 5 speed and this one has a 6. I noticed it had trouble finding the correct gear. Is that a symptom of something? Bug in the programming? Anything I should shy away from?
    2. Another problem is the passenger door doesn't unlock and open with the fob in pocket. Antenna issue?
    3. All 4 wheels show corrosion. Due to buildup of brake dust I can only imagine. The dealer offered to scuff and paint all the wheels a silver color. I don't like that idea, I'd rather something from a bone yard if available.
    4. It has OEM Michelins on it and rides very hard. Even in the touring programming. I didn't notice a difference switching to sport or whatever the other setting is. My 2005 although older isn't that stiff.
    Thoughts?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    Re: Quirks with an 08 1SG; Transmission, door unlock, very very stiff ride
    Don't carry your fob in the same pocket as your cell phone. They interfere with one another.
    Don't mess with Binky Bear!
    Dino1SG is offline Cadillac Owners Fanatic
    May 2014
    114
    The transmission may have an updated calibration available but it may also be simply the fact that you don't drive the way the previous owner did. The exterior handle may need to be replaced or it may also be that the previous/current owner had/has that feature turned off in the configuration settings. I would look into a quote from a wheel repair shop that can do refinish them properly, around here there's a place that can do it for probably around $200 a rim, and there's mobile guy that can do it for even less, and come to you, although you get what you pay for. Also keep in mind that six or seven year old tires may not have the same characteristics they once had when they were new, and that may be one more expense that will come early on in the ownership.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    6 year old Michelins will be very hard. Have you thought about your next set? Tires do age.
    Apr 2009
    Central MA
    49
    483
    Thanks for the info guys. I didn't see anything in the programming that shut off capability to unlock and open passenger door. All I found was when unlocking doors, unlock driver side or all doors simultaneously. I tried moving the FOB all around the passenger door and nothing opened. The red light came on however telling me someone is trying to open the door without a FOB. Anyhow I may pass on this particular car and keep looking around. Not sure yet.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    It's the antenna (door handle). If the car is otherwise what you want, use it to start a list of IOU items for the dealer/seller. Even if warranted, I'd get an inspection by your mechanic.
    Apr 2009
    Central MA
    49
    483
    Aurora5000's Avatar
    Aurora5000 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Blackberry,2004 CTS 3.6 Loaded, 2016 SRX LOADED
    Oct 2003
    Tornado Alley Oklahoma City
    482
    Also riding rough could be as simple as overinflated tires. I run 30-32 PSI. I also agree with Echas3 on tires.
    Apr 2009
    Central MA
    49
    483
    I double posted sorry...
    Anyway I also noticed that the steering has a lot less road feel if you will. It was so easy to turn the wheel like there wasn't any sporty feeling in the steering. Maybe another symptom of over inflated tires? My 2005 had just the right amount of push back when turning the wheel. My thoughts anyway...
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    It must not have NV7 - PREMIUM ZF STEERING GEAR. Are you sure it's really a 1SG?
    It really doesn't sound all that well cared for. Here are a couple of good questions to ask before buying any used car, even if in good mechanical condition or warranted:
    Is the finish in good condition and a color you like?
    Is the car clean (especially those spots that most people skip: under the hood, battery cover, B-pillar with doors open, sunroof well, trunk surround & spare well)?
    A car that was cherished by its previous owner will usually respond to your investment(s) in it.
    Apr 2009
    Central MA
    49
    483
    Ah I thought it was a 1SG simply because of its features. HUD, ACC, Blind Spot, Lane Departure. With all those options, would they leave off the NV7? Can we tell by the VIN somehow? The carpets needed shampooing but it is in decent shape. I want the 08 or an 09 and they are becoming harder and harder to come by unfortunately.
    Anyway, great questions to ask before any purchase, agreed!
  14. Remove Advertisements
