Horrible V6 mpg (12-15mpg avg) and rough idle w/ ac on
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By ddgm
  • 1 Post By EChas3
Cadillac STS Forum - 2005 through 2012 Discussion, Horrible V6 mpg (12-15mpg avg) and rough idle w/ ac on in Past Cadillac Vehicle Discussion; Hi everyone, thank you for reading and helping out. I did search but didnt find many answers. I have a ...
    Tfreestyle is offline Cadillac Owners Member
    Automobile(s): 06 Sts V6, 04 Escalade EXT, 01 Sts (past), 1995 Sts(past)
    Sep 2006
    Tarzana, Ca
    24
    Hi everyone, thank you for reading and helping out. I did search but didnt find many answers. I have a 2006 Cadillac Sts v6 that is constantly getting just horrible gas mileage. Manually calculating the mpg im getting between 13-15 avg per tank. about 50/50 city highway. Best I have ever gotten was 19-20mpg on the freeway to vegas at 70-75mph, one tank there and one tank back both with the same results. Also to add I have a rough idle that is amplified when I turn on the a/c that has been going on for a long time too. I replaced the spark plugs about 2k miles ago as a fingers crossed fix for the idle, helped a bit but not that much. The car now has 98k miles. No codes.
    Im not an overly aggressive driver but not a grandma so a few mpg off id understand but this seems very excessive. Any ideas of what could be going on? I am bringing the car in for the rear diff bushing to a friends shop(not a cadillac shop) so if there is anything we can check over while there i will have access to lift for a few hours.
    Wojciech is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS 3.6 DI 2009 RHD with Performance Pkg
    Feb 2014
    Southampton, UK
    166
    Re: Horrible V6 mpg (12-15mpg avg) and rough idle w/ ac on
    If you saying it's happing when A/C is ON maybe there is problem.
    Problem with compressor? Maybe belt is not stretch enough or tensioner fail?
    KRSTS Guest
    I average 19.8 on mine combined. You have a malfunction. Take it to a dealer for a proper diagnosis.
    ddgm is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    270
    I would try a good cleaning of the throttle body. The V6s are equipped with the 3.42 rear differential which does have an effect on the mileage. However when I drove mine
    1500 miles back and forth to Florida, I was getting somewhere in the 25-27 MPG range. I was considering switching to a higher gear ratio but as I now fly to Florida, I have abandoned that approach. By the way, mine doesn't use any oil.
    Doug
    kcaughron likes this.
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Vacuum leak? Like the N* motors possibly, loose intake plenum bolts?
    Mine gets poor mileage and it's been getting worse since I got it a year ago due to the vacuum leak which I need to address. Getting the P0174 code on the reg.
    Sep 2006
    Tarzana, Ca
    24
    Bringing the car in tomorrow. Going to pull the plugs and see what they look like after looking for a vacuum leak.
    It's not only when I have the ac on its just a little more amplified when on.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Did you use OEM plugs?
    KRSTS likes this.
    Sep 2006
    Tarzana, Ca
    24
    Oem plugs were used. Ended up being the fuel filter was causing the rough idle. Once we got a new one in there no more vibration. Time to see if that is the reason for the bad fuel economy too. Putting in another air filter as a precaution.
    Eldo1953's Avatar
    Eldo1953 is offline Cadillac Owners Enthusiast
    Automobile(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
    Feb 2003
    Winnipeg, MB
    756
    Where is the fuel filter on these and how do you change it?
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Under the car on the passenger side rail. A special tool to remove. Very easy. Danny
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Inboard of Right Rear - at least on V8's. I believe they are all the same.
    It used to be part of recommended service but was dropped ~ '07..
  14. Remove Advertisements
