Cant get rear rotors off!! 2005 sts awd
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Cadillac STS Forum - 2005 through 2012 Discussion, Cant get rear rotors off!! 2005 sts awd in Past Cadillac Vehicle Discussion; I've gotten every thing off in regards to changing my brakes, but now i cannot get the rotor to come ...
    The15Kid is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Aug 2014
    4
    I've gotten every thing off in regards to changing my brakes, but now i cannot get the rotor to come off of my 2005 sts awd. I've banged on it some to try and loosen it up but it will not budge. I'm not sure if there is some sort of trick to it, but please someone advise me on this situation!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Cant get rear rotors off!! 2005 sts awd
    Is there a small hex bolt holding it on? I've made that mistake ONE time, I'll never do it again...
    Aug 2014
    4
    There was a T30 screw on it and a 36mm bolt in the middle....I've gotten them both off/out but Rotor will still not budge!! Ugh!
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    I did a brake job earlier this year on a friends car and literally had to soak them in LiquidWrench and beat the crap out of them with a 5# sledge before they came off.
    Sounds like you have everything removed just have a little nature on your hands. Be mindful of the lugs, don't bend them suckers.
    stevenriz is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    483
    I used a small hand held sledge hammer and kept going until they freed up. Hit all around the pad surface.
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    thekid15, The rear brake rotors has a small brake drum built inside the rotor. This is for the E-brake. Back off the adjustment on the back side of the rotor assembly. It should then slide off. But first put some liquid wrench on front side of rotor at the center hub. Danny
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Quote Originally Posted by curtc
    Ha, guilty of that as well.
    Aug 2014
    4
    THANKS everyone for the input!! I finally got them off! Soaked 'em in WD40 for about 20 minutes then beat the hell out of them! They eventually agreed with that! LOL
    Thanks again everyone!
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by The15Kid
    For future reference WD-40 is NOT a penetrant its a lubricant. It is never a substitute for PB Blaster.
    Dec 2012
    275
    Quote Originally Posted by 1BadCadSTS
    News to me. Mental note made.
    I've used stuff called liquid wrench that works pretty well too.
    Mar 2012
    columbus ohio
    382
    Sometime I like to use the blue wrench. For those that don't know what this is a big gas acetylene torch. Danny
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,632
    And people wonder why I put anti seize between the rotors and hubs(and rims). Nothing like beating a frozen on rotor or drum off a car.
    Mar 2012
    columbus ohio
    382
    When using anti-seize I wear rubber glove. Be careful, the anti-seize will end up on every thing. On my arm, behind my ear, down my pants. Danny
  16. #14
    rodnok01's Avatar
    Feb 2012
    NC
    6,632
    Quote Originally Posted by dannyquest View Post
    LOL yes it will and then migrate onto the wife's clothes in the laundry... THEN life really sucks.
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    Penetrating oil=Mouse Milk. It was developed for disassembling turbine engines.
    When pounding around on your car parts it's wise to use a brass hammer so you don't ding them all up.
    Don't mess with Binky Bear!
  18. Remove Advertisements
