Strutmasters Install
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, Strutmasters Install in Past Cadillac Vehicle Discussion; Got the strutmasters kit for the rears on my car. Install took a bit too long (only did one side ...
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Install took a bit too long (only did one side for now).
    I installed the new spring bottom first which apparently was incorrect. Spring sits bowed out a bit.
    Doing the other side today and redoing the first attempt. Hopefully it sits better. Will post pics.
    Jneedom14 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2013
    41
    42
    Re: Strutmasters Install
    Post a picture of it and does it ride better or worse.
    Dec 2012
    275
    Quote Originally Posted by Jneedom14
    All done, took about 1.25 hours per side.
    Helps to read the instructions specifically... Said to push the top of the spring all the way in until it touches the bump stop.
    Everything is square, tight and right.
    Rides great. No more bottoming out going over speed bumps.
    Pretty stiff back there which is fine. Ride height unchanged.
    I would recommend. Paid $380 USD before shipping and taxes. Comes with plug in resistors that seem to work fine; no issues yet.
