Results 1 to 12 of 12
Thread: No start no crank
    bigred197701 is offline Cadillac Owners Member
    Automobile(s): eldorado
    Jul 2014
    63
    Unhappy No start no crank
    I have a 2005 Cadillac STS with a v6 keyless entry it will not start or crank with the remote or the starter button on the dash .I hit the start button and everything goes black for 20 seconds then the hole dash comes back ON. I pulled the starter button out of the dash to check for voltage at the back side of the button there are ten wires plugged in to it a light/blue with a white strip it had 13.5 battery voltage I pushed the starter button and the voltage dropped to 4.75 at the light/blue wires and 4.75 on the output side. The Light/Blue with White strip wire to the starter button can anybody tell me what voltage is at the starter switch and where that wire gets its power from. I need help thanks
    mIAn is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2014
    Saudi Arabia
    122
    Re: No start no crank
    Just loose the battery terminals for 3o secs and then tight the terminals .
    hope it will work for u.
    i will wait for ur feedback
    Mar 2012
    columbus ohio
    382
    Bigred, This happened to me one day. A new battery fixed it. Danny
  5. #4
    Aurora5000's Avatar
    Aurora5000 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Blackberry,2004 CTS 3.6 Loaded, 2016 SRX LOADED
    Oct 2003
    Tornado Alley Oklahoma City
    482
    what he said^^^^
  6. #5
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,016
    Almost certainly a bad battery. Quite common with these cars.
  7. #6
    Jul 2013
    145
    Yes. My car battery was working great all summer. Then I noticed the cranking was getting slower. My car sat in my garage for 7 days and it was dead. New battery fixed it!
  8. #7
    Jul 2014
    63
    Battery has been disconnected a number of times it didn't work thanks Need to no where the l/bl wire with a wh strip gets it power and what the voltage is
  9. #8
    KRSTS Guest
    you need a NEW battery
  10. #9
    Jun 2009
    2,016
    If you don't want to believe it's a bad battery yet, put your volt meter on the battery terminals while someone tries to start it and see how low the voltage drops.
  11. #10
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,549
    AC Delco batteries have been rumored often to hold a great 'surface charge' ... meaning that it looks full until you try to start it and when you press the button to start it drops to the floor.
  12. #11
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    A failing battery can look good when not stressed. These cars stress batteries regularly.
  13. #12
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    It's also possible that you have a bad ground from the back of the engine to the battery. That guy wiggled loose on me, and i had exactly the same symptoms.
    If the dash is going black, that means the ECU is attempting to start the car, which means the button is working fine. You've got something else going on further down the chain. Either a bad ground, a bad battery, a bad starter, or a bad starter solenoid. You could also have a bad starter relay. I'd start at the relay and then work from there with a meter and see where you're losing power.
  • You may not post replies
